Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By rusty502
  • 1 Post By sparkeater79
    Default I am still not crazy how my Note 10.1 uses 2.41 of 2.71 ram. does root and custom rom help?
    I clear cache and it only goes down to 1.8ish. But just a few minutes later it is back up to 2.4ish. When rooted and running custom roms does this tablet still use so much ram? It just seems like i am not doing much so why does the thing run so close to maximum? This tablet has outrageous specs, i hope Sammy can get it right with an update. I am trying to not root so soon, but i may have no choice. Do you lose any features when running custom roms? I am not well schooled in the art of mobile technology but i am informed and up to date with a thirst to learn more. Any ideas....
  2. #2
    Default Re: I am still not crazy how my note uses 2.41 of 2.71 ram. does root and custom rom help?
    Are you having performance problems? If not, don't worry about it, Android will clear ram as it needs it, your note has plenty, it will manage it just fine on its own.
    Golfdriver97 likes this.
  3. #3
    And, yes you will lose some things such as s pen function with custom roms, you will also trip knox, which may cause problems in case of a warranty claim.
  4. #4
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,696 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Not to mention that Knox has been doing a wonderful job at blocking the flashing of custom ROMs.
    From a Sprint Moto X using AC Forums app
  5. #5
    Posts
    Global Posts
    32,696 Global Posts
    Carrier
    Quote Originally Posted by sparkeater79 View Post
    You could try to clear up some RAM by disabling applications. But in Android's case, empty RAM is wasted.
  6. #6
    Quote Originally Posted by rusty502 View Post
    It depends what ROM you install. AOSP ones will not have S Pen and multi-window. I don't know it anybody has made such a ROM for this tablet. There is CleanROM on xda, I'm running it last 2 weeks. It's based on stock so all the good things are available. Very stable and fast. And yes, rooting affects knox, do it at your risk.
    BUT, you don't have to do it in order to use less RAM. Unused memory in Android is wasted memory. OS manages RAM well, you should not wary about it. There are many posts about it here and on xda.
  7. #7
  8. Thread Author  Thread Author    #8
    Thanks for the info. I searched for a topic along these lines , I just didn't word it right. I am happy to hear that my worries are not necessary. I do experience lag, and hope it will be cleared up soon. When I use my droid dna every screen, every app, everything I do on it is faster. I know it is a phone but it is a year older than my tablet......
  9. #9
    Posts
    Global Posts
    32,696 Global Posts
    Carrier
    Thanks for the follow up.
  10. #10
    GeekCop's Avatar
    Posts
    Global Posts
    187 Global Posts
    Quote Originally Posted by Golfdriver97 View Post
    Which is why as soon as I rooted my Note, I went into Titanium Backup and froze Knox.
  11. #11
    Posts
    Global Posts
    32,696 Global Posts
    Carrier
    Quote Originally Posted by GeekCop View Post
    Does that freeze the bootloader portion of Knox?
  12. #12
    GeekCop's Avatar
    Posts
    Global Posts
    187 Global Posts
    It seems so. When I first rooted my Note, I got the warning icon in the status bar from Knox. Once I froze it, it went away. I rebooted and it didnt reappear.
  13. #13
    Posts
    Global Posts
    32,696 Global Posts
    Carrier
    Cool. Hope it works for flashing ROMs.
  1. Replies: 3
    Last Post: 02-15-2014, 04:19 PM
  2. POP up on my Note 3
    By Stewby85 in forum AT&T Samsung Galaxy Note 3
    Last Post: 02-07-2014, 07:18 PM
  3. Kk launcher someone help me out here.
    By delta7 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-07-2014, 08:56 PM
  4. Replies: 1
    Last Post: 01-07-2014, 08:35 PM
  5. Data is being used while using wifi
    By xonq in forum Samsung Galaxy S4
    Last Post: 01-07-2014, 07:48 PM
