I bought the note 10.1 2014 from amazon a week ago. Even after updates I had lag. Also had flash issues. There is such a thing as a lag free tablet. I ordered a second one yesterday from amazon same 32 gb white tablet and am using it now to type this. The only thing after the updates I've changed is using nova as my launcher. But touch wiz worked a lot more smoother than the other one. This tablet is much faster and smoother and I set up flash in a flash. So if you are disabling a lot of apps and turning off animations just to smooth out lag, return yours and get another one. I'm happy I did. On this tablet I'm still running default animations and haven't turned one app off for lag reduction. Now I will test battery with apps on and get back to you as far as battery life. It was decent on the other tablet. I'm sure I'll turn off some to save battery in a couple days after I check if this new tablet has better battery life. Some apps are sluggish but scrolling is smooth, no trouble with YouTube or Netflix either. Robbielyn
