Results 1 to 5 of 5
Like Tree3Likes
  • 2 Post By capsfloyd
  • 1 Post By SpookDroid
    capsfloyd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Brightness setting-problem
    Need help . Grandson played on it , now it's dim .went in to settings , display , briteness will not click on ...help
  2. #2
    Paul627g's Avatar
    Posts
    Global Posts
    17,762 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Brightness setting-problem
    Hello,
    You mentioned going into Settings/Display, did you check to make sure " AUTO " was checked? If your grandson changed the brightness to a low setting then it will remain dim/bright, where ever it was set to.
  3. #3
    SpookDroid's Avatar
    Posts
    Global Posts
    11,684 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You should also check the Battery Saving options. I believe there's a setting there for brightness, too, but I'm not sure.
    capsfloyd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Found the problem . Never noticed the % of battery . Was down to 2% . Plugged in and everything is fine
    Thanks
    SpookDroid and Paul627g like this.
  5. #5
    SpookDroid's Avatar
    Posts
    Global Posts
    11,684 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hehehe That was my next suggestion, but never thought of it until now :P Yeah, if your tablet goes below 5% (I think), the darkness sets in. Awful when you're trying to view the last two minutes of your favorite show :P
    Uschiekid likes this.
  1. Replies: 1
    Last Post: 01-28-2014, 08:24 AM
  2. S Note Problems
    By bassbandit in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-25-2014, 09:04 AM
  3. Nexus 10 Tablet - Problems getting around flash player
    By stepaul8 in forum Google Nexus 10 Tablet
    Last Post: 01-23-2014, 04:32 PM
  4. A problem with my Nexus 7 screen!
    By iDoc86 in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-21-2014, 09:27 AM
  5. Galaxy S3: mic problem
    By andrew93d in forum General Help and How To
    Last Post: 01-20-2014, 10:13 AM
