Results 1 to 19 of 19
Like Tree2Likes
  • 1 Post By B. Diddy
  • 1 Post By charles777
  • 1 Post By dianehelen
  • 1 Post By joedm126
  • 1 Post By Shawn Waldo
    Default Wifi speed?
    My question is how fast should I expect my wifi speed to be when I have 50 megabyte download speed on my internet? The speed just doesn't seem as fast as I thought it would be. I tested my desktop and I am get close to 58, but when I tested the tablet wifi it said I was getting about 5 but 11 upload speed. Not sure what I should be getting and if this is normal or if I need a faster router. Thanks.
  2. #2
    Default Re: Wifi speed?
    Use a program on your computer like InSSIDer to see what nearby wifi networks are using which channels, and to see if your wifi network is using a congested channel. If so, you could log into your router's settings and change its wifi channel.
    Also, are you using any wifi extenders? Some of them can degrade the download speed.
    mrsmumbles likes this.
  3. #3
    Quote Originally Posted by joedm126 View Post
    I have 30mb wired Internet speed and with a dual band router, I am connected to the 5GHz band and the Speedtest app clocks my tablet at 31mbps down and 12mbps up.
    I would definitely look at your router setup.
    Hope that helps
  4. #4
    I agree, the channel selection is key, especially if you are in an area with alot of dwellings that have in home networks. Most routers will default to use channel 1 or 2. So most of the networks in range will share/fight for bandwidth on those channels. I just put mine on ch 1 and my speed went from 25/6 on my regular channel 6, to 9/4 on channel 1. There are 6 other neighbors networks on ch 1, just me I ch 6 :-)
    Thanks everyone. I tried changing the channels and i now have between 14-21MB depending on where I am in the house. I think I will call my provider any see if there are any other settings I should change.
    B. Diddy likes this.
  6. #6
    I live in the sticks with no nearby homes, so the airwaves are uncluttered. Just wondering, can you select a different channel per device, so other users on the same network, eg the missus who's constantly online, doesn't impact on my bandwidth?
  7. #7
    Nope, the channel is for the router, not the devices.
  8. #8
    That's wot I thought, but thanks for confirming.
  9. #9
    You live in the "sticks" and have a 50MB download speed? What internet provider do you have? I live in the sticks too (no cable) and have to rely on satellite. Here's a picture to make you feel good about yourself <lol>
Name:	2014-01-24 08.09.06.png
    Quote Originally Posted by Dr Law View Post
  10. #10
    Au contraire, you jumped to conclusions there, now you can feel smug, as I only get 5 on a good day!
  11. Thread Author  Thread Author    #11
    Update - Apparently my Router is a little too old and I was told the max speed I would get with this router is 20 MB on a wireless device. The other problem is that I can find a channel that works well and get between 15-20MB and then the next day that same channel is only about 5. I don't know what is going on and why the speed of the channel would change from day to day even with 11 channels to chose from.
  12. #12
    Routers are often set to Automatic when it comes to channel selection, so they're supposed to pick a channel that isn't very congested. If your router doesn't have an automatic setting, perhaps the channel it's set to suddenly became more congested with other nearby routers that decided to pick that channel for the day. Or maybe there's just a lot of wi-fi traffic near you, meaning all of the channels are kind of congested.
    Although there are 11 channels, I believe there are realistically only 3 main channels to choose from, because there's some spread--it's usually channel 1, channel 6, or channel 11.
  13. #13
    The 10.3 Mbps speed shown above (and advertised by Hughesnet as what I should be getting on my plan) isn't the same as the 1.2MB/sec speed when I'm downloading, for instance, a program.
    Trust me, unless someone is on dialup, I pretty well have the slowest internet connection of anyone I know. Not a competition I want to win <g>
  14. #14
    Meet me. 263kb/s is the max download speed I actually get when downloading anything. Not on dialup. Cue feeling superior now.
  15. #15
    What router do you use any router within the last few years should be able to get 54 mbps.... check your wireless settings and see what band it it broad casting.... Some routers broadcast in b and g signals which b is older and way slower you should be able to switch the router to g only and pick up some speed... I went from 4-5 up to my normal 15ish with that switch
  16. Thread Author  Thread Author    #16
    I have my router set to automatic now and it seems to okay for now but it was set to automatic when this started. I have fios and there h guy told me that this router would only provide about 20 mb and i would have to upgrade the router for more. He said there were no other settings go to change besides the channel. He logged into my router and looked around and tried different channels. No real difference. I have fios about 5 years or so and the router is my original. I am getting about 56mb to my desktop.
    just checked and once again i am only getting about 5mb.
  17. #17
    With out know the model(GEN) of router its hard to say.. if it irks you terribly you could switch to a different router.... Although if you anything like me you like the free mods best.. if you are able to find model number and then look up specs on it it should tell you what you can really expect to see wireless wise... I am not expertly vesrsed in verizon products but this link may also help. How to Get the Fastest FiOS Speed - Page 6 - Verizon Forums
  18. #18
    Quote Originally Posted by Shawn Waldo View Post
    I'm not talking the max speed posted on the router.... That is not the problem...I can set it to 300mbps, doesn't make a difference if the internet speed in my area is crap, which it is. I'm talking about the ACTUAL download speed....I mean if I monitor the speed while downloading or streaming with a network system monitor. I live where it used to be rural.... and the lines were always crappy. Then they put in a huge housing development across the street, but not new lines, so instead of 25 houses sharing crappy lines, there are now probably a few thousand.... More every year are being built, overtaxing an already burdened system. Called the company many times, they refuse to do anything, and they are the only option here.
    btw, I wasn't looking for a solution...I've tried anything and everything, I'm just happy they aren't doing the massive construction that meant no Internet for days on end anymore....I just was having a bit of fun joining in when everyone was comparing the worst Internet... All of which sounded amazing to me
  19. #19
    oh well that makes sense *its all so clear now*..sorry wasn't trying to hi-jack the thread must have misinterpreted and wanted to throw my .02 in FWIW..
    Uschiekid likes this.
  1. Can't connect to Wifi connection. Please help!
    By Erika Contreras in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 09-16-2015, 10:18 AM
  2. Samsung Galaxy Tab 2 10.1 WiFi won't turn ON
    By pooja19s in forum Samsung Galaxy Tab 2 10.1
    Last Post: 07-21-2014, 11:08 AM
  3. Verizon Speeds are awesome!
    By mfldmike in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-24-2014, 03:17 PM
  4. Wifi connected but will not work
    By Emily Welsh in forum HTC One X
    Last Post: 01-18-2014, 12:47 PM
  5. Codegen Tablet Wifi TURNS OFF itself in 5 seconds!! PLEASE HELP ME!
    By beguler in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-18-2014, 12:09 PM
