Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By SpookDroid
    jyoung42's Avatar
    Posts
    Global Posts
    4 Global Posts
    Default Note 10.1: battery life
    what is the average battery life that most of you are getting? I am only getting about 1.5 to 2 hours per charge and this seems VERY low. Most of the time I cannot complete a movie or use the tablet throughout the day at work without plugging it in after each meeting.
    I do have the power saving feature turned on.
  2. #2
    Default Re: battery life
    something is very wrong there. I get about 8 hours on a full charge, using it a moderate amount. with light use it can last about 10 hours. Do you have the brightness turned all the way up? The screen takes alot of power. I keep it at about half way
  3. #3
    I have the auto screen brightness and the power saver turned on I can probably browse and play games 10ish hours on a full charge straight it last a couple of days with low/light use
    jyoung42's Avatar
    Posts
    Global Posts
    4 Global Posts
    I am going to have to send my unit into samsung. With auto brightness and power saver I am lucky if I get 2 hours of use out of it.
  5. #5
    I am newbie, with that said, they could have put a 3.0 usb on the 2014, and made a replaceable battery option.. IMO, those two options would greatly increase user time with this device. My Note 3 charges fast, plus I carry an extra battery. On the other hand, my Note 2014, doesn't charge fast, and no removable battery option..With that said, I put my Note 2014 on the charger whenever it is convenient..
  6. #6
    Default Re: Note 10.1: battery life
    I get 12 plus hours... I read a lot about shorter battery life for this device before I brought it. My findings were that bloatware was mostly the cause for the shorter life... I disabled most bloatware and specifically most Samsung bloatware and push services... I get the same life out of my battery on this as my older Tab 2 10.1...
    Samsung Galaxy Note 10.1 2014 Edition (WiFi)
    Samsung Galaxy Tab 2 10.1 (WiFi)
    Samsung Galaxy S3 (AT&T)
  7. #7
    Quote Originally Posted by cehowardNote3 View Post
    Just to clarify, USB 3.0 DOES NOT charge your device any faster, it just transfers data that way. The charger's AMP rating or the USB port you're using, however, does make a difference. That, and of course the fact that these are two different batteries with very different capacities. Using the same charger (Note 3 and Note 10.1 have the same charger, btw) of course you'll notice the Note 3 charging "faster"... you can't expect to fill a 1L glass of water in the same time it takes you to fill a 500ml one with the same water faucet, can you?
    dianehelen likes this.
  8. #8
    I am a newbie! Could you tell me what is bloatware and how to take it off? Thanks.
  9. #9
    Quote Originally Posted by lbabus View Post
    Another newbie (5 or 6 days old) 2nd that. A nice list of what to take out of the GN 2014 and what they do and don't do would be nice. Made a sticky too..
    Andriod Central is the BOMB!!!. :
    D
  1. Sony Xperia Z1s Battery - WOW!
    By luke31 in forum Sony Xperia Z1s
    Last Post: 07-13-2014, 10:17 AM
  2. Please Help, Battery drain after repair
    By Jay_876 in forum AT&T Samsung Galaxy S4
    Last Post: 01-28-2014, 11:21 AM
  3. Verizon LG G2: Battery question
    By Jeffrey Shubert in forum Verizon LG G2
    Last Post: 01-27-2014, 11:17 PM
  4. battery saving apps
    By Benny515 in forum Sony Xperia Z
    Last Post: 01-26-2014, 02:28 AM
  5. Broke lcd, sudden battery drain after replacement screen
    By Jay_876 in forum Samsung Galaxy S4
    Last Post: 01-25-2014, 01:08 AM
