1. Astronomer cykiller's Avatar
    Hi, everytime I open Air-command and use screen write, I always get bad screenshots quality. Is this normal?
    Thanks for the help!!!
    01-27-2014 05:56 AM
  2. SpookDroid's Avatar
    Unfortunately, yes... for some reason using screen-write does compress the images a lot. If you want better results, I'd recommend taking the screenshot (but disabling the option to edit it after taking it), then adding the writing through the Photo Editor. I know it's going through extra steps but this way the quality of the picture is kept before writing onto it.
    01-27-2014 11:20 AM
  3. dianehelen's Avatar
    1. Where do you enable/disable option to edit after screen shot? When I take one, it just says "copied to clip board" then saves it in the pictures>screenshots folder
    2. What Photo Editor are you referring to? ok.wow just discovered the photo editor within the gallery appb ha! never knew that was there. Love finding new things about this tablet every day :-D
    01-27-2014 11:27 AM
  4. Uschiekid's Avatar
    @dianehelen Settings-device-display...."edit after screen capture"
    @spookdroid
    Are you saying even though I both situations I get 2650x1600 resolution, one is actually better because of the manner in which the other is compressed?
    01-27-2014 11:43 AM
  5. dianehelen's Avatar
    @spookdroid
    duhhh thanks, it was right there
    01-27-2014 11:53 AM
  6. SpookDroid's Avatar
    Yup, the compression algorithm for the edited screenshot is higher than the one used for 'pure' screenshot. For instance, you can save a JPEG file in MS Paint and have the very same image saved in Photoshop, and the latter will look better (but have a larger file size). Why? MS Paint has a higher compression rate than the default Photoshop settings (yes, you can change the settings in PS and end up with an even blockier picture, but that's another thing).
    01-27-2014 03:59 PM
  7. Astronomer cykiller's Avatar
    Thanks for the help. I wish Samsung will fix this!
    01-27-2014 04:38 PM
  1. Verizon S4: ROM Flashing problems
    By Iroxusux in forum Verizon Samsung Galaxy S4
    Last Post: 01-13-2015, 04:17 AM
  2. Problem bluetooth for samsung Galaxy S3 Mini...
    By Carsi Canim Feda in forum Samsung Galaxy S3 Mini
    Last Post: 08-08-2014, 09:21 AM
  3. Can't remove apps at bottom of screen
    By Rilla1 in forum Samsung Galaxy Tab 2 10.1
    Last Post: 02-05-2014, 10:56 PM
  4. S4 stuck on AT&T firmware screen
    By Austin Alexander in forum Samsung Galaxy S4
    Last Post: 02-02-2014, 10:53 AM
  5. Does the new Android 4.3 for galaxy S3 have problems??
    By Pratik7 in forum Samsung Galaxy S3
    Last Post: 01-29-2014, 12:59 PM
