Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By charles777
  • 1 Post By Mai Dvices
  • 1 Post By dianehelen
    Default Galaxy Note 10.1: Weird charging question
    When I charge my Note overnight, leaving it on, when I take it off the charger in the morning it shows 100% charged. But if I turn it off(power down) to charge, when I turn it on(boot up) in the morning it shows charged to 99%.
    Any ideas why it does this?
  2. #2
    Default Re: Wierd charging question
    I think I remember reading somewhere that batteries don't fully charge even when it says 100%.
  3. #3
    Simple sync problem of how the software reads the batt level. In my case i simply use it till it shutsdown and charge it back to 100%.
    Sent from my Elcheapo Movimax P5
    ya but how do you explain the difference between when it's charged from on or off?
  5. #5
    Quote Originally Posted by dianehelen View Post
    That is a bit strange unless booting the device uses up 1% of the juice
    dianehelen likes this.
    huh , interesting theory, I can buy that
    Thanks Charles
  7. #7
    Thanks Charles
    No prob... with all the background processes that need to start up on our PC like tablet, it might just be the answer... but no real way to prove it
  8. #8
    Probably internal clock running in processor pulls a little juice even with power off.....
    Dale
  9. #9
    http://gizmodo.com/how-to-take-care-...ht-w-513217256
    http://batteryuniversity.com/learn/a...ased_batteries
    Not sure the 1% theory, but from the above article what do you think on the charging over night???
  10. #10
    I think that is because of the battery is not well calibrated, that means the android system cant read the battery stats right. How long have you been using the note, and how are your charge/discharge cycles? For example, i left my note charging overnight and powered on this morning, quickly checked my emails and then i turned off wifi, and left it with power saving feature on, then when i got home four hours later, the note still got 100% percent battery left. Also to make things clear i dont use many background sync apps like facebook, twitter, google now and so on, also currently using just 1 widget and a simple live wallpaper.
    I dont think you should worry about this 99% issue even though is an annoyance, to put things in perspective my old phone (a sony ericsson xperia play) had this issue, at first i worried a lot and thought i had a defective battery or charger, but after some research i found that my screen on time was the average, and after a month or so of use i noticed that the battery lasted more in the 0-15% range, instead now i noticed that my note 10.1 2014 last longer from the 20-100%, the last 20% discharges really quickly, but as with the xperia, the screen on time of my note is perfect.
  11. Thread Author  Thread Author    #11
    I'm not really worried about this, more curious. I get great battery performance, close to 11 hours, depending on what I'm doing. I also don't use any constant synch apps, just 1 weather widget, static wallpapers, keep brightness pretty low.
  12. #12
    From my observation, the100 to 99% doesnt really have any adverse affect on uptime on my note. With myusage habits and brightness setting, i seem to constantly end up with around 40% battery level by 9pm
    Don't worry bout it diane, the 99 is the new 100 !
    Sent from my SM-P601 using Tapatalk
  13. Thread Author  Thread Author    #13
    Ha! ;-)
    I've had my tablet on now since 10am, I had to go out for about an hour, mid day, plugged into charger for that hour, it's now 10:30 pm and I'm at 34%! Very happy with battery performance
    Mai Dvices likes this.
  14. #14
    A possibility should the battery reading actually be that accurate:
    After charging with it powered off, the boot process is going to use a short burst of power. Maybe just enough for a 1 percent down tick. So maybe your note is not 1 percent shy of perfection after all.
  15. #15
    I have been reading a couple threads here and on XDA forums concerning charging issues.. Such as, takng a long time to charge, going down real fast. So, before my 15 day return period is up, yesterday, I let my GN 2014 run all the way down to would only allow me to power off. I put it on chage this morning at 7 am at about 11, I looked at the charging icon and it looked as it was near full. I had been reading that better results are obtained when it is close to 80 or 90% full, to unplug the charger and then plug it back in to continuing charging. With that done, at 12 noon, exactly 5 hours later, it showed a 100%. Glad of that, It would be a hassle to put all the things back in the box, and take off the beautiful tempered glass screen I have attached. So, it looks like I am keeping this one. Now just wondering should I get the protection plan that Bestbuy offers before my 15 days are up.. ???
  16. #16
    Default Re: Galaxy Note 10.1: Weird charging question
    Like clockwork...i charge my note at night. Unplug by 6 am and auto on at 8 am. Always charge while device turned off. Been using to browse, prospecting, ereading calculating..smsing even calling twice..and its 20.29 right now and my battery is on 65%. Niiiceeeee
    Oh yeah, my setting is auto brightness, 3g on, timeout screen 2 mins. Never used it for music or film or play games.
  1. I have a question about Android app
    By neivian in forum Android Central Apps
    Last Post: 02-06-2014, 10:26 PM
  2. Chrome Bookmarks question
    By agp423 in forum Android Apps
    Last Post: 01-27-2014, 06:35 PM
  3. google wallet tap and pay question
    By KBlack2595 in forum Android 4.4 KitKat
    Last Post: 01-27-2014, 04:16 PM
  4. GS4 Charging trouble ?
    By 9Nine09 in forum Samsung Galaxy S4
    Last Post: 01-27-2014, 01:05 PM
  5. Miscellaneous files question
    By ansa82 in forum Verizon Galaxy Note 2
    Last Post: 01-27-2014, 10:45 AM
