Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By nb22
    nb22's Avatar
    Posts
    Default s pen won't write on one bit of screen above home button
    Can anyone help please? I've had my Note 10.1 2014 for less than a week and love it but noticed that when I take notes with s pen I can't write on a spot about 2 cm above the home button (bottom middle of screen). It sends the pen strokes wildly all over the place. I can get around it by turning the Note upside down to finish my page or not writing on bottom 3 or 4 lines of page at all but neither is a very good solution. Letter 'b' hard to press with pen too. Do all Note 10.1 2014s do this or is it a fault? Need to know if I should send it back. Got light bleed at bottom of screen too which is very disappointing after coming from great build quality of an ipad. Many thanks for your advice.
  2. #2
    Default Re: s pen won't write on one bit of screen above home button
    I had "Swipe Home button" on, which occupies that area, and it works all right with the pen. I then disabled it and tried writing around with the pen on Snote. Now, SNote shows the page number in that area, so it's awkward to write there, but when I started outside that area and crossed it with the Spen, the lines seemed normal.
    So I guess it is a problem with your unit.
    [EDIT] Tried on lecturenotes, that area seemed normal too
  3. #3
    Quote Originally Posted by nb22 View Post
    Do you have a case/cover on your Note ? Some of the cases with embedded magnets result in wonky writing abilities with the S Pen. If you do have a case on... take it off and test again... you never know
    nb22's Avatar
    Posts
    Thanks. Are you able to write a word directly above the page number? Mine really struggles it's like there's a spot the pen is avoiding.
  5. #5
    I don't have the tablet with me but I will check this evening. I guess the cover wasn't the problem
    nb22's Avatar
    Posts
    Brilliant! Thanks charles777! I do keep it in a case that has magnets. Have taken it out and it's working perfectly. Will get another case now. Cheers!
    charles777 likes this.
  7. #7
    Glad to hear
    Now you can enjoy your tablet !
  8. #8
    Mind posting what case it was for us and future reference that caused the problem?
  9. #9
    Glad it's solved. Just FYI, mine does work above the page number, and I do have a case with magnets, though the magnets are located on the other end of the tablet, on the corners of the long side that has the Samsung logo
  10. #10
    I guess I didn't hit post earlier today when I replied to this.
    I have the Poetic case...LOVE it! Great case. It's magnetic. I can
    write all the way to the very edge of the bottom of the screen. This case,
    unlike the Moko case, also allows me to do a swipe for a screen capture.
    It's never caused any problems with my GN/2014.
  11. #11
    Thank you so much for this. This problem was driving me crazy!
  12. #12
    Quote Originally Posted by charles777 View Post
    Thanks! That was the problem with mine. An area near the magnetic clasp appeared to be much less likely to detect the pen input. It works fine when removed from the case - and exhibits the same problem again when reinserted into the case. :-)
  1. Replies: 8
    Last Post: 02-21-2014, 06:14 PM
  2. AT&T HTC One X update live
    By Tom_Sewell in forum HTC One X
    Last Post: 02-20-2014, 08:30 AM
  3. Music starts playing on loudspeaker when I hang up the phone
    By heading4tomorrow in forum AT&T LG G2
    Last Post: 01-29-2014, 01:07 PM
  4. Replies: 1
    Last Post: 01-29-2014, 12:52 PM
  5. Phone won't rotate..!
    By tastycaramel in forum Samsung Galaxy S4
    Last Post: 01-29-2014, 09:32 AM
