1. sandiegosteve's Avatar
    I'm working hard to figure out how to use S Note and keep organized.
    I just found this: S Note for PC
    It seems pretty cool. I am able to see notes (almost), edit them and sync with my device. I am using Evernote to sync.
    When I started it up, I saw no notes even after entering EN information.
    Then I created a note with the PC app. It shows up in both EN and on my Note. I opened it on the Note, added a picture and it synced to both EN and my PC. Very cool.
    But... it puts it in the "Pictures" folder on EN. I can't find any way to configure a folder for sync.
    I want to keep my notes organized in EN, and random notes in "Pictures" and "Notes" isn't going to cut it for me. This is so close...
    sicunder36 likes this.
    03-03-2014 04:32 PM
  2. johnling's Avatar
    I can stay sync'd with snow fine so I know that works. I have not tried it with EN. Sync with snot once and see if it's an EN problem....
    Sent from my SM-P600 using Tapatalk
    03-03-2014 04:41 PM
  3. sicunder36's Avatar
    i can sync the notes i create on my snote pc with evernote and then edit them on mobile snote on my evernote android client.
    but the notes i make on snote android syncs up with evernote on windows but not with snote windows client.
    in simple words,
    snote on pc => evernote server ======> evernote android=> android snote -------working fine through out
    but,
    snote android => evernote android=======>evernote server====> evernote on pc (till here working fine ) but==XXXX==> (blocked) snote pc
    hepl please!
    07-12-2015 11:31 PM
  4. kevjey's Avatar
    If I create on the pc it won't show up on my note 10.1.
    But it works the other way.
    If I add any content to any notes it doesn't sync either way.
    Is there some settings etc I need to change.
    Back to onenote.
    Kev...
    07-13-2015 06:55 AM
  1. Best Anti-Virus Software for Android
    By xVxM4tthewxVx in forum Android Security Apps, Tips & Strategies
    Last Post: 02-14-2017, 08:49 AM
  2. Note 3 4.4.2 reboot
    By CombatChicken in forum Samsung Galaxy Note 3
    Last Post: 03-16-2014, 08:11 PM
  3. Get the S4 or wait for S5??
    By jcochran1977 in forum Samsung Galaxy S4
    Last Post: 03-05-2014, 04:20 PM
  4. Emails not sync-ing with server on G2?
    By llewis233 in forum LG G2
    Last Post: 03-04-2014, 10:58 AM
  5. Help! Evo stuck in loop
    By kkeev in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 03-04-2014, 12:20 AM
