1. superjoe95's Avatar
    Anyone know where to order a longer USB cable that will still charge the device properly? I'm worried if I buy just any ol' USB cable that it won't work properly. Thanks!
    03-29-2014 03:43 PM
  2. wizzrah's Avatar
    Here is a 6 foot micro usb to usb cable on Amazon:
    Amazon.com: AmazonBasics USB Cable - 2.0 A Male to Micro B (6 Feet / 1.8 Meters): Electronics
    I have it and it charges devices fine.
    03-29-2014 03:47 PM
  3. geoffwhite18's Avatar
    I bought one at walmart. It's about a foot longer than the oem one. It came with a charger that supplies 1.5 amps and seems to work fine while plugged into the Samsung charger.
    03-29-2014 11:16 PM
  4. monicakm's Avatar
    I have the OEM charging cable connected to a THREE foot indoor extension cord (found it at Lowes). Is this OK to use? This seems to be a polarizing debate.
    03-30-2014 01:33 AM
  5. Dale_M's Avatar
    Quality and wire gauge in cable construction is of issue here.... Small cable with tiny wire gauge has to much internal resistance and drops voltage going to tablet, and you get the red "X"....... Larger gauge wire has less internal resistance there for less voltage drop there for no red "X" in charge indicator...
    Also with chargers.... Samsung tablet charger puts out 5.1 volts at 2.1 amps (2100ma) anything less is not big enough to supply correct voltage and amperage to succeed in decent charge times.... Specification are there for reason, and its all about design criteria, you want to play mix and match with underrated parts, you pay consequences...
    All I can suggest is you try extension cable, if you do not get red "X" when powered up tablet with charge cable connected you are probably good to go....
    I have a heavy duty 3 foot extension (off web camera or something that died in past) on my note 10.1 for about 3 months now and everything is ok.... Actual cable diameter of extension is larger than Samsung supplied cord (if it matters)...
    Dale
    boudicca00 likes this.
    03-30-2014 10:11 AM
  1. Replies: 7
    Last Post: 08-20-2014, 05:44 AM
  2. Second charge cable?
    By Tayloj92 in forum Sprint LG G2
    Last Post: 04-05-2014, 09:50 AM
  3. How to use USB OTG MICRO USB
    By strong-heart in forum Samsung Galaxy S3
    Last Post: 04-04-2014, 06:16 PM
  4. Samsung Galaxy S3, running 4.3 - USB Connection issue
    By WordPad in forum Samsung Galaxy SIII I9300
    Last Post: 03-29-2014, 01:21 PM
  5. Galaxy S3 Mega disconnecting /reconnecting from USB port
    By EvilLiberal666 in forum General Help and How To
    Last Post: 03-28-2014, 10:22 AM
