Re: Battery life way short of the suggested 9 hours
I want 80% brightness because I want it and the iPad air I get 11-12 hours of screen time compared to 4 with the note 10.1 2014 edition.... $1000 dollars to get 8 hours of screen time is not even worth the money and a crazy suggestion.... I used both tablets in the same condition at 80% brightness, Web browsing, watching movies and 15 minutes of a game (total not at once) and as I said 11-12 hours of screen time with the iPad vs 4 on the note 10.1 2014 which is horrible. I shouldn't need to charge it more and Google needs to make Android use more battery management.
Sent from my SM-N900T
Just charge it and stop worrying about it.
I have both an Ipad 4 and my note. The Ipad yes does last a little longer but in everyday use I don't notice it because rather than worry whether the battery is going to run out of charge or not I charge it.
I never need 80% brightness unless outside in the sun, 20-30% is fine in most places and the screen brightness is the killer.
I have never let mine get below 20% it's called planning. If I go on a 10 hour flight then I expect it to run out so I take a book or watch the inflight entertainment or sleep.
Batteries discharge, get used to it.
Buy 2 tabs or a portable recharger, plan ahead.
