1. Kulu21's Avatar
    Hi
    I live in London England and have just (yesterday) bought a Note 10.1 2014 edition running Android 4.3.
    Watchon seems to work in principle in that I can use it to control the TV, but the programme guide is hopelessly off - I have tried resetting it with each of the TV provider options that I am given by the tablet and none of them work - has anyone else in London or the UK had this as a problem? If so, have you been able to fix it?
    My second question is about the Android version - should we be getting an upgrade to 4.4?
    Many thanksin advance
    04-29-2014 03:36 PM
  2. Raymond Hubbard's Avatar
    Did you buy the tablet in the UK or the US or possibly another country. When you set it up did you make certain the UK was the country you set up? It might be linking to the wrong server. Here in the United States Kit Kat WiFi rolled out last week. Give it awhile and it should come to your country soon. I have read that Spain has the upgrade. The UK must not be far behind.
    04-29-2014 05:02 PM
  3. Kulu21's Avatar
    Hi. I bought the tablet in the UK and made sure it is set up for the UK - it's all very strange.
    Thank you for confirming the position re Kit Kat - I will keep an eye out.
    04-30-2014 03:33 PM
  1. Calendar issues after KitKat update
    By damage_inc in forum Verizon Samsung Galaxy S4
    Last Post: 06-14-2014, 07:31 AM
  2. Random battery power problems
    By wrburg in forum Samsung Galaxy S3
    Last Post: 04-30-2014, 03:16 PM
  3. super problem
    By Fahrudin Zudin in forum HTC One X Rooting, ROMs, & Hacks
    Last Post: 04-30-2014, 10:43 AM
  4. Rooting Galaxy S4 after KitKat update.
    By Glenuendo in forum Verizon Samsung Galaxy S4
    Last Post: 04-30-2014, 07:53 AM
  5. Problem syncing music. Help?
    By DroidRooter in forum Samsung Galaxy S4
    Last Post: 04-30-2014, 04:09 AM
