Results 1 to 7 of 7
    monicakm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Did KK Fix the BT Keyboard Connectivity Problem?
    For those of you have had a problem keeping your BT keyboards connected, did KK help? Hope so!
  2. #2
    SpookDroid's Avatar
    Posts
    Global Posts
    11,706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Did KK Fix the BT Keyboard Connectivity Problem?
    Nope, mine still does it. I'm afraid this IS a hardware issue rather than software
    What I've done and it usually helps (sometimes it just won't stay connected, though) is reboot, turn WiFi off, turn BT on, connect the keyboard, type something with it (to force it to really connect, not just pair), then re-enable WiFi. Or just keep WiFi off :P
    monicakm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Oh that's right. I totally forgot about it being a hardware issue. Sorry
  4. #4
    Dale_M's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Could it possibly be a issue with BT Keyboard and not with Tablet why it won't stay connected.... Just a thought , not into Bluetooth hardware ...
    Dale
  5. #5
    jimcapraro's Avatar
    Posts
    Global Posts
    116 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have two BT keyboards - A Motorola BT keyboard that matched to my original XOOM purcased in 2011, and ane even older ThinkOutstide Stowawy foldable BT keyboard I bought about 15 years ago. Both connect and stay connected with no problem. I've never had either of them disconnect unless I intentionally disconnect them. I can even leave it overnight whan I come back in the morning once I start typing on the BT keyboard a little message appears on the bottom of the GN 10.1 screen telling me the keyboard re-connected.
    Sent from my SM-P605V using Tapatalk
    monicakm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Dale_M View Post
    Dale
    I wouldn't think so Dale since some of us have no problem with the BT keyboards. My Logitech K810 has never disconnected. My Jawbone Jambox BT speaker has never disconnected. I can transfer files via BT between all my devices.
    What is it about BT hardware you don't like? Just curious.
  7. #7
    Dale_M's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Nothing.... I don't have one and its not in my immediate future..... IT was just a thought...
    Dale
  1. S-View flip cover randomly stops doing the auto wake on/off
    By eyecon82 in forum Samsung Galaxy S5
    Last Post: 01-28-2016, 07:47 PM
  2. Replies: 9
    Last Post: 10-06-2014, 02:08 PM
  3. Logitech Pro keyboard confusion.
    By agrajag27 in forum Samsung Galaxy Note Pro 12.2
    Last Post: 05-12-2014, 05:49 PM
  4. The Daily how much data have you used thread
    By dpham00 in forum General News & Discussion
    Last Post: 05-10-2014, 04:03 AM
  5. where is the screen on time stat?
    By GoBigRed4 in forum Motorola Droid MAXX
    Last Post: 05-09-2014, 06:29 PM
