Results 1 to 4 of 4
    den1959's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Advanced KtKat setting... how do I get to it
    Hello all, My KitKat upgrade down loaded a couple of weeks ago. I like it so far, there been a few things I don't. One being I have to have the GPS on all the time, which is a battery killer. But I have read some were you can go into the advanceed setting mode for KitKat. And set it so you can use only the wifi like my Android version, before KitKat uploaded. How do I do this? I have Samsung note 10.1 2014 tablet.
    I also can no longer screen capture using my pen. Yeah some were the DMR protected shots. Any thoughts on a screen capture software that will allow screen capture of DMR protected video. I am not interested in capturing the whole video though. SOme are video game shots.... yeah to help me figure out how to advance...
    Thanks all
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,060 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Advanced KtKat setting... how do I get to it
    Quote Originally Posted by den1959 View Post
    Thanks all
    The GPS should be under location in settings. Change it from High accuracy to battery saving.
    den1959's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the reply. But when I turn off Location which is now the GPS button, my location will not be shared with my different programs, like local news, local weather etc... SO I was looking to get to the advanced setting...
  4. #4
    SpookDroid's Avatar
    Posts
    Global Posts
    11,675 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That's also something I hated from the update... You can long-press the Location button (which used to be GPS) and it'll take you to the settings. There, you can choose to let apps know your location based on GPS, on WiFi, on both, or none.
    I've listed a few of my likes/dislikes here:
    KitKat Update: Likes and Dislikes
  1. Replies: 18
    Last Post: 05-17-2014, 12:05 PM
  2. Replies: 1
    Last Post: 05-12-2014, 11:29 AM
  3. Sound does not reset when toggling from 'vibrate' to 'sound'
    By pre2930 in forum Verizon Galaxy S3
    Last Post: 05-10-2014, 04:02 PM
  4. How to remove CyanogenMod from Acer Iconia A500
    By jociepoo in forum Acer Iconia A500
    Last Post: 05-09-2014, 04:49 PM
  5. How to Invoke Lockscreen?
    By ksat in forum Samsung Galaxy S5
    Last Post: 05-09-2014, 11:29 AM
