Was checking out the factory reset using power on/volume up/menu button and when prompted to press up to continue or press down meant to press down and instead pressed up which threw up the downloading screen do not turn off.
It has been running for over an hour and no change and want to know if it is really down loading or stuck.
Tablet is WIFI version and had KITKAT 4.4.2 on it.
What are my options at this point?
Wait out the download if working?
Power off and restart?
I have plugged in the charger so it does not run out of power while waiting.
Thanks for any help you can provide.
..CWBOFTx
..CWBOFTx
