1. monicakm's Avatar
    I don't play games on my GN/2014 but I have two on there for my grandchildren and they both cause the tablet to get uncomfortably hot. That can't be good. One game is Juice Cubes, the other is Hay Day. Both of these were downloaded from the Play Store. I know heat and expansion is a killer for our devices. Should I stop letting them play the games? Can a software update from the dev fix the problem?
    Thanks,
    Monica
    07-03-2014 01:47 PM
  2. monicakm's Avatar
    Has anyone else experienced their tablet heating up significantly during game play? I don't know if this is normal or if I should uninstall the games.
    07-05-2014 10:06 PM
  3. geoffwhite18's Avatar
    Mine gets very warm while playing games. In fact it routinely crashes while playing games as well.
    07-06-2014 01:18 AM
  4. John Woo1's Avatar
    Its normal that all devices get hot while playing games and CPU/GPU running at max speeds. I would rather worry, if it doesnt getting hot, than its not running as maxed full speed as it should.
    Since all mobile devices are thin and it limits cooling on CPU/GPU and heat are unvoidable. Tablets are much bigger than smartphones and can spread heats much better than small smartphones with limit spaces.
    Mine Note 2 with 1.6 Ghz feels much hotter than Note 2014 with 2,3 Ghz.
    Enable power saving mode and it will limit CPU speed and cause less heats.
    07-07-2014 07:04 AM
  1. Game List
    By Craphex in forum Software Development and Hacking
    Last Post: 01-09-2015, 11:17 AM
  2. "Google Cloud Save" games?
    By sam142000 in forum General Help and How To
    Last Post: 09-11-2014, 10:41 AM
  3. Free Addictive Game: Race Fun
    By rocktunegames in forum Android Games
    Last Post: 07-15-2014, 01:19 AM
  4. New free retro arcade game(and more)
    By SD90 in forum Android Apps
    Last Post: 07-03-2014, 10:24 PM
  5. Game controller for Tab Pro 10.1
    By brettt777 in forum Samsung Galaxy Tab Pro 10.1
    Last Post: 07-03-2014, 08:32 AM
