1. keem5's Avatar
    I was excited about my new tablet so i started to set it up all that... then i realized when tablet is connected to my laptop (via usb) it says "not charging" battery has a red X on. is this normal, does anyone had the same issue?
    08-08-2014 09:41 PM
  2. B. Diddy's Avatar
    The laptop might not provide enough current to charge your tablet adequately. Does anything else charge ok when hooked up to the laptop?
    keem5 likes this.
    08-08-2014 09:50 PM
  3. keem5's Avatar
    yeap it does, when i connect my galaxy note 2 (smartphone) it does charge just fine.
    08-08-2014 11:00 PM
  4. B. Diddy's Avatar
    But the tablet still charges normally from the wall outlet? Compare the original chargers from both your tablet and phone--do they both draw the same amperage? If the phone draws significantly less amperage than the tablet, then maybe that's why it's able to charge from the laptop. But I'm not an electrical engineer, so I may be way off base here.
    08-08-2014 11:04 PM
  5. keem5's Avatar
    yea its charged when connected wall outlet, but i am using the same usb cord that i use both tablet and the phone. i wasnt sure if this was a common issue or just me?
    well thanks anyways.
    08-08-2014 11:44 PM
  6. MarkHansen's Avatar
    Note: The red X over the charge indicator does not mean it's not charging. It means it's charging at a lower rate. The tablet detects that it is connected to a computer USB port and reduces the amount of current it draws to protect the computer.
    B. Diddy likes this.
    08-09-2014 08:37 AM
  7. Dale_M's Avatar
    Note to all others.... USE charger that comes with table, and charge tablet to full charge before initial use.... Saves you a lot of headache....
    Dale
    08-09-2014 09:22 AM
  8. sure why not's Avatar
    The recommended charger is 2.1A or more.
    USB 2.0 is limited to 500mA (1/2A) by design.
    It is NOT the tablet side limiting current.
    It may keep up with your use, but it would not charge at an acceptable rate.
    Hence the red slash.
    Tomcat31b likes this.
    08-09-2014 02:08 PM
  9. cdahncke's Avatar
    Power off the tablet and it will charge. Otherwise you need to use the high power tablet charger.
    08-12-2014 10:00 PM
  10. Tuan Em's Avatar
    yeap it does
    08-14-2014 04:21 AM
  1. Samsung Galaxy S6 Release Date and Spec Rumors
    By jcp007 in forum Samsung Galaxy S6
    Last Post: 02-03-2015, 09:02 AM
  2. [New] Mid-Autumn Festival LWP 2014
    By Lee Kai in forum Wallpapers, Ringtones, and Themes
    Last Post: 08-08-2014, 10:00 PM
  3. Replies: 1
    Last Post: 08-08-2014, 09:31 PM
