1. londo49's Avatar
    My brand new galaxy tab 4 (sm-t530) can't or won't recognize my supplied otg cable, but my Samsung s3 will, easily. My question is ' what can I do about it?. I need the otg to work in order to access WiFi network (prepaid dangle with dodo). Any help or advice would be appreciated. Thanks
    08-24-2014 11:31 PM
  2. Raymond Hubbard's Avatar
    Some Samsung Devices have a 5 pin connection while others have 11 pin. I believe the S3 has 5 pins while the tab 4 might have 11 pins. If this is the case that is the reason it doesn't work.
    08-25-2014 08:55 AM
  3. Dale_M's Avatar
    On OGT cable (micro 5 pin) check with ohm meter that pins 4 and 5 are either connected together with solid short or a 1k resistor... IF not, its not a proper OTG cable...
    If its a 11 pin connector, I do not have solution for you...
    Dale
    08-25-2014 11:14 AM
  1. OTG cable that supports charging at the same time
    By popengchan in forum Samsung Galaxy Note Pro 12.2
    Last Post: 10-06-2015, 09:12 PM
  2. OTG cable that supports charging at the same time
    By popengchan in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 08-25-2014, 11:03 AM
  3. Samsung Galaxy S 4 and Note 8 WiFi Connection Problems
    Last Post: 08-24-2014, 11:17 PM
  4. OTG cables that supports charging at the same time
    By popengchan in forum Samsung Galaxy S5
    Last Post: 08-24-2014, 10:14 PM
  5. OTG Cable that supports charging of the device at the same time
    By popengchan in forum Samsung Galaxy Note 3
    Last Post: 08-24-2014, 10:12 PM
