I wanted to replace my old battery, which at first I thought was having problems. It seemed like I was getting about the normal amount of screen time on it, but then my son ran a game for about 15 minutes on the tablet. It had about 80% charge, then shut down and had no charge in that amount of time.
I ordered a replacement battery, which initially worked well, then it wouldn't charge properly. I've been reading the forums, and have done the following:
1) Replaced battery
2) Replaced charger (with Genuine Samsung)
3) Replaced charging cable.
4) Replaced USB connector assembly w/ribbon cable (in case it was the connector)
I did find in these forums about the cracked battery connector problems. I also tried resoldering, but not sure how to do it. I do have the tools to resolder. I tried heating each of the 6 pins up with the battery disconnected, and applying a small amount of solder. This is on the side with the connector.
The new battery now will not charge, but when I plug the tablet in, if I push on the connector, the screen flickers from dim to bright. When I put the old battery back in, everything was great, for a few days.
Now I'm getting the same problem with it not charging right. I pressed on the back cover of the tablet, and now it is charging right.
My question to the forum is this: Should I try resoldering with more solder again? Do I need to remove the motherboard and solder on the underside? I have a magnifying glass, but couldn't see if the solder pads were on the top side of the connector, or if it is a "through-hole" where the actual solder pad is on the bottom of the board. I'm thinking now that maybe the other battery isn't bad, and one of the wires in the white connector was loose. I'm going to see if I can tighten them up and maybe the new battery isn't the problem. It seems to me like I'm still fighting an issue with the battery connector on the mainboard. Does this make sense?
1) Replaced battery
