I might be looking at getting a Note 10.1 but am after some advice first.
Firstly the 10.1 is the limit of my budget for an Android so any higher spec tablets with that OS aren't really an option.
The only tablet I've had before was an iPad Air which I may still end up getting instead but I was put off by the lack of expandable memory and if I'm not convinced enough by the 10.1 I'll probably go back to one of those.
When I had the iPad I noticed some iPhone apps aren't available for it, is that the same with some Android phone and tablet apps? I know with iOS you can get iPhone version apps working on the iPad, they just look expanded and over-film the screen slightly but still function well. And in case this is the only option to get around such a problem, I'm not really interested in rooting etc.
Also can you get iCloud push email on the Note via the built-in clients and without needing to download certain apps etc? I used to have a Galaxy S4 and you could get iCloud email in intervals unless I installed some app which I'd rather avoid.
Also are there any general 10.1 commonly reported problems?
Cheers all.
Cheers all.
