Results 1 to 2 of 2
    Default battery won't charge has a x in charge mode
    My battery won' t charge on my samsung tablet 10 1
  2. #2
    Default Re: battery won't charge has a x in charge mode
    Are you using the Samsung wall charger?.... Any other charge if its not a 2100ma (2.1 amp) does not supply enough voltage... Of if you are trying to charge off a USB port on computer, same issue not enough voltage/amperage and red "X" ... Any wall charger the will supply 5.1 volts DC and 2100ma should work, any thing less will "x".... IF you are using proper charger and have red "X" then you may have deeper issues with battery...
    Dale
    Diagonally parked in a parallel universe.
  1. Battery physically bent when changing screen.
    By stevez1337 in forum Google Nexus 4
    Last Post: 08-10-2014, 04:58 AM
  2. fast battery drain issues fyi...
    By corneredcat in forum Verizon LG G2
    Last Post: 05-18-2014, 11:38 PM
  3. Samsung Galaxy S4 Active Won't Update at All, Still 4.2.2
    By Matthew Covington in forum Samsung Galaxy S4 Active
    Last Post: 05-14-2014, 11:06 PM
  4. Replies: 2
    Last Post: 05-14-2014, 10:04 PM
  5. Custom App Icons in the Lock Screen?
    By Simon Sharp in forum HTC One (M8)
    Last Post: 05-14-2014, 07:48 PM
