Results 1 to 7 of 7
    Default Note 10.1 and car charger compatibility
    Trying to charge my Note with my Griffin car usb charger, charger shows green light, when plug in to Note, charger shows red light, and Note battery icon shows a red X. Is my charger not powerful enough?
    P.S. charger works with my mp3 player.
  2. #2
    Default Re: Note 10.1 and car charger compatibility
    Yep, that means you probably have a 1 Amp charger which works fine for phones and mp3 players but not tablets.
    Get rid of all the randomness in the world and you will have a world without hamsters.
    Thanked by:
  3. #3
    I can recommend the Belkin Car Charger for Galaxy Tablets. Got one from Amazon, works great.
  4. #4
    ongre10's Avatar
    Posts
    Global Posts
    72 Global Posts
    Your tablet needs a higher amperage charger make sure it is 2.0 amps or above. A lower amp charger may work if the tablet is off but may take a long time.
  5. #5
    I have a galaxy Note 10.1 and bought a green ring Belkin Car charger (2.1 A) and this one also doesn't work. Same thing: Note battery icon shows a red X and no charging. There must be something else than the 2 A alone.
  6. #6
    I have 2 different 2.1 amp plugs, and have tried with two different cables. No way it works. I think the tablet can recognize if you use a samsung charger, and only allows that. I also have a 2 amp wall charger, same thing. Only when I use the charger that came with the pad, and the expensive car charger I had to buy, will it work. Clever bastards!
  7. #7
  1. Sold: Verizon Galaxy Nexus w/ extended battery and car charger
    By scorpiodsu in forum Sold / Archived Marketplace Threads
    Last Post: 07-06-2012, 06:48 PM
  2. Car dock and Car Charger Recommendations
    By brichter45 in forum EVO Accessories
    Last Post: 07-13-2010, 01:06 AM
  3. Additional Wall Charger and Car Charger
    By lawnboy in forum Verizon Droid Incredible
    Last Post: 07-06-2010, 06:35 AM
  4. car chargers and nav
    By jamesy in forum Incredible Accessories
    Last Post: 06-24-2010, 12:30 PM
  5. Replies: 3
    Last Post: 05-26-2010, 12:24 PM
