Results 1 to 11 of 11
    Default Hdmi interface, no sound
    What did I forget?
    Connected note 10.1 using samsung hdmi adapter. Got picture but no sound from the external tv. Just from the note. What did I do wrong ?
    thanks
    Sent from my GT-N8010 using Android Central Forums
  2. #2
    Default Re: Hdmi interface, no sound
    Did you plug in the power connector? - it is required.
    I found that I had to increase the volume on my Sony TV from a normal of about 20 to 50 to get good volume.
    Loren
    Yes.the power was connected and volume was max
    I found the the problem
    My vid cable is good for dvd (vid + sound) but not good for tablet (no sound)
    New hdmi cable solved the issue
  5. #5
    Do you have a link to the cables you ordered?
    No. I got it with Samsung's dvd but it is a standard one just the new/current cabel 'model'
  7. #7
    I have the same problem. The Rocketfish HDMI cable doesn't work. Video no sound. Some have recommended turning the volume on the TV to max. Others have suggested audio patch cables through the headphone jack. I just want an HDMI cable that works.
    Sent From My Samsung Galaxy Note 10.1 Tablet
  8. #8
    Which HDMI adapter from the Note are you using? Where did you get it?
  9. #9
    Jesus H Christ are we still dealing with this crap neigh on 2013? There are so many products and variants of products it's like you have to be a bloody engineer to research all the nuances before you buy anything. Most people would have thought a HDMI cable was a HDMI cable. I was wondering why the sound didn't work on mine too. So are there two types and how do you distinguish if it's once that also does sound when you buy one?
  10. #10
    Quote Originally Posted by LandLockedPH View Post
    Ordered it from Samsung. You can probably find it on Amazon as well.
  11. Thread Author  Thread Author    #11
    I got hdmi interface at ebay.it is the original one and work perfect. Just first you have to connect it to the power before conecting to the hdmi cable, otherwise it may not be showed on the tv
  1. Genuine Samsung SGS III HDMI Adapter - No Sound on TV
    By Tom S. in forum AT&T Galaxy S3 Accessories
    Last Post: 11-11-2012, 09:11 PM
  2. No sound with HDMI to front projector?
    By sweepsnregs in forum T-Mobile G2x
    Last Post: 11-17-2011, 08:51 PM
  3. No sound using HDMI cable
    By Cole World in forum Google TV
    Last Post: 08-30-2011, 11:05 AM
  4. Help no sound
    By joe_5962 in forum HTC Droid Eris
    Last Post: 02-22-2010, 06:37 PM
  5. Video has no sound
    By zeravla531 in forum HTC Hero
    Last Post: 01-07-2010, 07:56 PM
