We're having the same issue. Our Samsung Galaxy Note 10.1 GT-N8013 16GB (White) won't charge from the AC/USB adapter but it will charge when connected to a PC via USB. When charging from the AC power brick, the battery icon at the bottom right of the screen shows a lightning bolt and indicates that it is charging. It sometimes works after the tablet has been charging from the PC/USB first -- then for some reason you can charge via the AC power / USB brick adapter. When charging from the PC/USB port, there is a red "X" on the batter icon in the lower right portion of the screen. It seems to me that the issue is with the AC mode charging. I suspect the issue is somewhere in the OS rather than the physical AC/USB power brick itself.
- - - Updated - - -
We're having the same issue. Our Samsung Galaxy Note 10.1 GT-N8013 16GB (White) won't charge from the AC/USB adapter but it will charge when connected to a PC via USB. When charging from the AC power brick, the battery icon at the bottom right of the screen shows a lightning bolt and indicates that it is charging. It sometimes works after the tablet has been charging from the PC/USB first -- then for some reason you can charge via the AC power / USB brick adapter. When charging from the PC/USB port, there is a red "X" on the batter icon in the lower right portion of the screen. It seems to me that the issue is with the AC mode charging. I suspect the issue is somewhere in the OS rather than the physical AC/USB power brick itself. We're running Jelly Bean 4.1.2 currently.
