Results 1 to 3 of 3
    Default Help registering
    Can anyone help me with this: When I attempt to register my device, it asks me for device and gives 3 choices for GT-N8013. The problem is that the writing on the back of my device is so small I can't read the letters that follow 8013 (old eyes), and I don't have a magnifying glass. I have deduced that the 3 choices are 16GB white, 16GB deep grey, and 32 GB deep grey. Does anyone know what the letters that follow 8013 are for the 32GB model? Thanks. Edit: I should have added that I am talking about the WI-FI only version.
    Edit.: Forget it. Took it out in sunlight. Found it. Sorry to bother you.
  2. #2
    Default Re: Help registering
    Quote Originally Posted by Ron Johnson 4164 View Post
    Darn those old eyes. I have the same problems.
    Sent from my GT-N8010 using Tapatalk HD
  3. #3
    J Teezy's Avatar
    Posts
    Global Posts
    201 Global Posts
    glad you found it
    Sent from my GT-N8013 using Android Central Forums
  1. checkbook register app
    By Lurch81#AC in forum Android Applications
    Last Post: 12-18-2010, 10:50 AM
  2. letters not registering after touching them?
    By bizN in forum Verizon Droid Incredible
    Last Post: 05-20-2010, 09:41 AM
  3. WaveSecure... Anyone else having trouble registering?
    By Ignitros in forum Android Applications
    Last Post: 01-16-2010, 06:39 PM
