1. J Teezy's Avatar
    been trying to find a good multi USB port charger that outputs enough amps to charge up a couple devices at the same time. Mainly looking at charging a galaxy S3. 10000 mah battery pack (most likely this would be charging through its own outlet but could be times when it needs to go into the USB power center) and galaxy note 10.1 tablet and possibly the girlfriends iPhone 4s (i get on her everyday about getting on android). To get a decent charge rate to the tablet need 2 amps charging for it alone. These are the only two i've really found
    Amazon.com: Skiva PowerFlow QuadFire (4 Amps / 20Watt / Fastest Speed) Four Port USB Wall/Travel/AC Rapid Charger for iPhone 5 4 4s 3, iPad 3 2 1, iPod, Samsung Galaxy Tab, Android Smartphones and Other USB Devices (Universal Compatibility): Kindle S
    Amazon.com: RND Power Solutions Premium 4.2A (fast) 4 Port USB AC Adapter / Wall charger for iPads, iPhones, Tablets, Smartphones, MP3 Players and Gaming Devices (black): Cell Phones & Accessories
    Anyone know of any other ones that supply at leats 4amps across the board or more?
    01-06-2013 11:24 PM
  2. FoneFill's Avatar
    There doesn't appear to be much available for consumer 20W chargers. Which one are you currently using?
    -Charles
    FoneFill Restaurant Phone Chargers
    01-13-2013 01:14 PM
  3. J Teezy's Avatar
    Not using any trying to find one that can handle a tablet at 2 amps and a couple cell phones
    Sent from my SCH-I535 using Android Central Forums
    01-13-2013 01:23 PM
  4. GMJeff's Avatar
    Read the fine print to be sure how the ports are laid out.
    You want at least one port to be 2.0 amp, but one of the two you mentioned appears to have three 1.3 amp ports, and no 2.0 amp.
    There is definitely a shortage of 2.0 amp chargers out there as tablets and larger cell phone batteries are fairly newer tech, so to say.
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    01-13-2013 01:44 PM
  1. Replies: 31
    Last Post: 10-04-2013, 04:42 PM
  2. Are all usb chargers the same?
    By whitenack in forum Incredible Accessories
    Last Post: 08-11-2010, 07:31 PM
  3. Does the Evo use a Micro USB charger?
    By kenmid EVO in forum HTC EVO 4G
    Last Post: 05-29-2010, 11:53 AM
  4. 2 port usb car charger
    By Jerry-O in forum EVO Accessories
    Last Post: 05-25-2010, 05:34 PM
  5. USB/Charger
    By mayer7196 in forum HTC Hero
    Last Post: 05-18-2010, 12:04 PM
