Does anyone know how to center words on the S Note document? Right now I use the space bar to move the cursor to the middle of the page. Very tedious.
Robert
Printable View
Robert
The best way I can think to do this is to select the 'Text mode' (to the left of the eraser) ,then give the Text mode button a 2nd short tap which brings up the text settings. Select the paragraphs tab ,which then allows you to align the text or use the indent option. If you give the Text mode button a long press it only brings up a cut down version of this dialogue.
S
