Results 1 to 5 of 5
- 01-16-2013, 12:26 PM
Thread Author #1
Otg USB cable not working?
I am trying to use a usb cable with my Note 10.1 to transfer files, etc. I am using a sandisk memory stick that has been formatted to Fat32. When I connect the cable to my Note, it says that a usb connection has been made and then nothing. I thought it was suppose to open the file explorer to view the folder. Also, the light on my memory stick doesn't come on when connected. I have seen a video on YouTube and the video demonstrates this with the same memory stick that I have. Am I doing something wrong? I just updated to JB last night, so I don't know if this causing the issue, but I doubt it. Any thoughts?
Sent from my GT-N8013 using Android Central Forums - 01-16-2013, 12:48 PM #2
- 01-23-2013, 10:46 AM
Thread Author #3
Re: Otg USB cable not working?
So I've figured out that after the upgrade to JB, I havent been able to use an OTG USB cable. My wifes Note was able to connect using the cable, but mine wouldnt. I upgraded her note to JB and tried the OTG cable, and her Note wont connect using the cable. Anyone else have the same issues? I dont know if there is some setting I need to change to allow the cable to connect. I have a memory stick that I want to transfer files from my work to my Note.
Sent from my GT-N8013 using Android Central Forums - 01-25-2013, 09:06 AM #4
- 05-01-2013, 12:19 PM #5
USB Debugging not working?
By Stevo14850 in forum Motorola Droid XReplies: 2Last Post: 11-15-2011, 12:20 AM -
USB Host not working for me
By buurin in forum Motorola XoomReplies: 2Last Post: 07-12-2011, 08:36 PM -
USB port not working on Evo
By saint117 in forum HTC EVO 4GReplies: 2Last Post: 02-10-2011, 09:41 AM -
Rooted and now mounting USB does not work!
By hayesb2 in forum AT&T Captivate Rooting, ROMs, and HacksReplies: 2Last Post: 09-06-2010, 05:12 PM -
usb drive not working help???
By Flip in forum HTC EVO 4GReplies: 6Last Post: 09-06-2010, 11:07 AM
Reply
