Results 1 to 3 of 3
    dunamis's Avatar
    Posts
    Global Posts
    234 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default help....factory reset or what?
    I tried updating to JB via kies and had problems in the beginning but finally did update. However, now I have this matrix thing happening on my screen on top right. I have these codes refreshing and continuously changing? Am I making sense? I tried to take picture but disappears when I try.
    Do I need to do a factory reset?
  2. #2
    lynnneil's Avatar
    Posts
    Global Posts
    99 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: help....factory reset or what?
    Yes. Do it and check.
  3. #3
    PeteJE's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sounds like settings, developer options, show cpu usage, is selected. Check first, maybe just uncheck that.
    Sent from my GT-N8013 using Tapatalk HD
  1. Factory reset or restore?? do both wipe the cellular settings
    By dBuster2012 in forum U.S. Cellular Mesmerize
    Last Post: 11-08-2012, 12:26 AM
  2. ICS update and then factory reset or vice versa?
    By h3seaking in forum Verizon HTC Rezound
    Last Post: 08-11-2012, 11:49 AM
  3. Help! Factory Reset Now No Google Access
    By Tinewen in forum Introductions
    Last Post: 07-07-2012, 11:22 AM
  4. Factory reset or Google backup keeping WiFi login info?
    By lazygroundhogs in forum Droid RAZR MAXX
    Last Post: 07-02-2012, 08:54 PM
  5. HELP!!!!! factory reset
    By PoisonStar in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 03-14-2012, 10:04 PM
