Adobe Flash Help
Twixx33
16
I know about adobe no longer being available on mobile devices but then i read in the forum where you can download archived adobe versions and that you can download browsers like firefox and be able to view flash required videos. I did both of these then went to sites that require flash for example, places that let you view sports online and nothing works.
Is this not what the archived version or browsers will do w/ adobe on the tablet?
J0n2
13
Hi,
I did this while it was running ICS but it seems to still work on JellyBean too.
Download this http://download.macromedia.com/pub/...roid/11.1.115.36/install_flash_player_ics.apk
Ensure you enable installing software
Install it
Using the default "Internet" browser it should then play flash. Chrome won't as it works different, and I haven't tried any other browser, as I use Chrome for everything else and use "Internet" if I need flash, which is usually just for BBC iPlayer live streams.
Rockdog97
181
Hi,
Install it
what do you mean by "Ensure you enable installing software?"
Chelsea rae
