DEAL OF THE DAY: Save 28% on the Seidio OBEX Waterproof Combo for Samsung Galaxy S3!
Results 1 to 4 of 4
    Default S Note Wrist Issue
    I have been using my Note 10.1 for about a week or so and I have one continuing issue. When using the S Note app in full page view my wrist always opens the Settings or Zooms me in. Does anyone have a way to hide the bottom settings bar and lock the zoom feature? It is probably the single most frustrating issue I have at the moment. Yes, I do use the wrist guard button but that only works on the live space you write on.
    Using the tablet is great since I moved over from the 1st Gen iPad which I basically wrote down all my notes on Penultimate. This new device destroys that tablet with this ability since I am a heavy note taker for business.
    Please help if you can. There is nothing I have found online to fix my problem. If I can fix this single issue or use another App for writing then let me know.
    Thanks!
    Thanked by:
  2. #2
    Default Re: S Note Wrist Issue
    I'm having that problem too. My OS is 4.1.2. Would love to see if anybody can help. Thank you for posting this question!
  3. #3
    Stump3r's Avatar
    Posts
    Global Posts
    79 Global Posts
    I have the exact same issue, I haven't found anyway to lock aspect or anything. I just try to keep up toward the top of the page and as I get to the bottom of the page try to lift my wrist and palm. Not exactly a perfect solution but it does seem to help.
    Yeah, it is pretty annoying when you get towards the bottom. I've wondered if you first keep the pen close to the screen if that would reduce the issue. So far I don't think that is the case. If anyone has any great ideas still waiting to hear them. In the App store I think I noticed an app that will move the home screen to the top. That could be extremely handy to change it's orientation.
  1. Replies: 2
    Last Post: 01-05-2013, 10:51 AM
  2. note 2 issue or no?
    By pnico in forum Verizon Galaxy Note 2
    Last Post: 12-16-2012, 10:09 PM
  3. Support galaxy note keyboard issue
    By fairycorpse in forum Samsung Galaxy Note
    Last Post: 12-07-2012, 11:22 PM
  4. Issues buying foreign GNex HSPA+ or G Note Unlocked?
    By Neon01 in forum Google / Samsung Galaxy Nexus
    Last Post: 11-04-2011, 06:39 AM
  5. Evernote audio notes recoding issue
    By jasxun in forum AT&T ATRIX
    Last Post: 05-11-2011, 12:06 AM
