Problem after update
I updated my note 10.1 to JB and now the screen goes black for no reason at different times.I can see the back light is still on, but no pic. The only way to fix is to reset it by pressing the power button twice. Anyone else having this problem? Please help! I tried a factory reset.....
Sent from my GT-N8013 using Android Central Forums
Re: Problem after update
Yep, had the same issue on 4.1.1... upgraded to 4.1.2 and have only had it happen once after using the stock gallery, which I no longer use, cause its crashing my note!
