1. Gilda Gomez's Avatar
    Ok, newbie here totally frustrated to find I can't move my apps and files to the external sd card. Yes, I have seen numerous posts here and elsewhere regarding this issue but no easy answer or steps. Is there a simple pc formatting program I can use to partition the card? To format the card?
    Yes, I have tons of crap on my tablet and need to shift stuff over to the sd card. Loads of music and photos plus a handful of books, pdf files, games, etc. What a pain! Is this a problem with Jelly Bean? I did not encounter this problem with my Samsung Galaxy 7plus; sold that baby to get my Note.
    My tablet is not rooted and I would prefer to keep it that way. Any guidance or link to a good set of steps would be very helpful.
    Thanks in advance!
    02-27-2013 07:12 PM
  2. DenverCZBob's Avatar
    Just start up the app "My Files". The left side of the screen should show you "Storage" and under that, "sdcard0" which is the internal storage, and also "extSdCard" which is of course your external sd card. Open sdcard0, select the files you want to move. Click on cut (scissors icon), then on the left side of the screen, navigate to extSdCard, select the folder you want the files to go to, click on paste (looks like a clipboard). There you go.
    -bob
    Gilda Gomez likes this.
    02-28-2013 08:16 PM
  3. Gilda Gomez's Avatar
    -bob
    Bob, thanks for responding! I will try it later today and if successful, will report back and spread the news. My question is a frequently asked one on numerous forums I discovered while researching this. No solution yet so let's try your instructions.
    Note, I hope that future OS development this problem is addressed and a fix added. Very frustrating to find you paid extra for a tablet because it has an external SD card slot only to find you can't use it to free up space on your tablet. Sucks.
    03-01-2013 06:39 AM
  4. DenverCZBob's Avatar
    If it helps, glad I could assist.
    This is of course for moving photos, videos. Not for moving apps.
    I think you gotta root in order to actually move the apps.
    -bob
    03-01-2013 08:45 PM
  5. giffer's Avatar
    -bob
    Thanks Bob!
    I was able to quickly move about 15 Gb of music, movies and picts to my SD card without any issues.
    03-08-2013 02:15 PM
  1. Moving SD card from S3 to Note 10.1
    By PhillyFlyer96 in forum Samsung Galaxy Note 10.1
    Last Post: 02-27-2013, 03:14 PM
  2. Proper Micro SD card for the note 2?
    By Yeargh in forum Verizon Galaxy Note 2
    Last Post: 02-14-2013, 12:51 PM
  3. move apps and data to the Ext. SD Card?
    By Lobonca in forum Droid RAZR MAXX
    Last Post: 05-24-2012, 03:29 PM
  4. Format SD card for better Battery life
    By SpaceDroid in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 10-24-2011, 06:25 PM
  5. Need Help Formatting Micro SD Card for G2X
    By Bmilano3161 in forum General Help and How To
    Last Post: 08-14-2011, 04:45 PM
