Results 1 to 5 of 5
    Default Using a projector from Note 10.1
    Hi can anyone tell me if its possible to connect a Philips Picopix pocket projector to a Samsung Note 10.1. On the Philips web site they confirm that it can be used on Apple products.
    Thanks
  2. #2
    Default Re: Using a projector from Note 10.1
    If the Philips has an HDMI connector, it is possible, but but it would require buying an HDMI adapter dongle from Samsung and of course a compatible HDMI connector between the pico projector and the Note 10.1 (via the samsung HDMI adapter). Another possibility is to connect to the Projector's USB input via the samsung charging data cable and play files off the Samsung as if it were attached storage. Frankly, I would just put the files you want to play on an SD card and play them back via the projector's integrated media player Unless of course you were looking to project the samsung screen in real time via the projector for game play - in that case you are back to the HDMI adapter route. Good luck.
  3. #3
    I had a related question as someone considering the note 10.1 for classroom instruction. I like what I have seen of the S Pen and S Note features, but does the note app output to the projector so that I could put lecture notes, diagrams, etc. on display for the whole class?
  4. #4
    jorang's Avatar
    Posts
    Global Posts
    356 Global Posts
    Suppose it's possible through the Samsung Allshare cast dongle.
    I have bought one for this purpose, but haven't tested it yet...
    Sent from my GT-I9300 using Tapatalk 2
    JoranG
  5. #5
    Quote Originally Posted by ryansmithwvc View Post
    Using HDMI out, you should get an exact copy of the screen on the projector. I've read that the HML to HDMI adaptor doesn't work properly and has been discontinued for the Note 10.1 (was looking into getting one myself). The AllShare Cast method seems to be Samsung approach now, which would be better for wandering around the class - no HDMI cable
  1. Transfer Contacts from Outlook 2007 to Galaxy note 10.1
    By RobertNW in forum Samsung Galaxy Note 10.1
    Last Post: 05-03-2013, 10:50 PM
  2. Connecting to Adhoc wifi networks from Samsung Galaxy Note 10.1
    By PaulMacc in forum Samsung Galaxy Note 10.1
    Last Post: 12-14-2012, 07:45 AM
  3. Fax from Your 10.1 Note
    By gyroslice in forum Samsung Galaxy Note 10.1
    Last Post: 10-06-2012, 06:44 AM
  4. Replies: 0
    Last Post: 09-25-2012, 06:00 PM
  5. 23 hours of use from a $10 battery
    By juice#ac in forum HTC EVO 4G
    Last Post: 08-03-2010, 05:22 PM
