1. JulieM26's Avatar
    My Galaxy tablet can't detect my wifi. I see it on my network list but it shows up dimmed and with the "not in range" message. This is silly because the box is right here, and all my other devices (mac, samsung phone, htc phone, galaxy tab 7) can see it and connect to it just fine. The only way I can get a connection on my tablet is by using my phone as a hotspot. That's ridiculous... I can't seem to find a solution. I tried software update, resetting the device... Any suggestions ? I don't want to do a factory reset. Thanks if you have any idea/solution you want to share.
    05-07-2013 10:20 AM
  2. ilgal's Avatar
    Occasionally I experience this issue and restarting the router clears it right up. I just warn other users in the house, unplug the router, wait 15-20 seconds, and plug it back in. I can then jump right on. It usually only happens if I've been on a different network (work, etc.). I think it's more of a router issue - my router forgets to deal out a new IP address or something.
    05-07-2013 03:21 PM
  3. rpeters33's Avatar
    I had the same issue with 3 different types of Samsung phones. To connect to my Wifi now I have to turn off data and then connect to WiFi. If I reconnect data, it turns off WiFi. Hope this helps.
    02-22-2014 07:49 AM
  1. Help! ICS ROM with no option to turn off fastboot- cannot get in
    By jamesbecker79 in forum Rezound Rooting, ROMs, and Hacks
    Last Post: 03-31-2014, 03:14 PM
  2. No option to 'partition sd card' in clockworkmod 6.0.1.2
    By prahe86 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 09-12-2012, 12:19 PM
  3. No Option to Connect USB
    By BelindaR in forum Samsung Galaxy S II Skyrocket
    Last Post: 07-03-2012, 06:12 PM
  4. No option to choose where to save contacts
    By vblok0910#WP in forum Verizon Droid Incredible 2
    Last Post: 06-03-2011, 07:39 PM
