Results 1 to 17 of 17
    Default How do I print a S Note? I don't have a Samsung printer.
    Sent from my GT-N8013 using Tapatalk 2
  2. #2
    DroidXcon's Avatar
    Posts
    Global Posts
    11,775 Global Posts
    ROM
    Stock for now
    Default Re: How do I print a S Note? I don't have a Samsung printer.
    There is an app called printshare in the play store. Try that
    From my Galaxy Note 2 via Tapatalk
    If i've made life easier buy me a Macchiato
  3. #3
    ishore's Avatar
    Posts
    Global Posts
    238 Global Posts
    Quote Originally Posted by DroidXcon View Post
    I use it all the time.
    sent from my Galalxt Note 10.1 using
  4. #4
    gldnbear's Avatar
    Posts
    Global Posts
    54 Global Posts
    It depends on the type of printer you have. If you have an HP ePrinter, HP has an app that allows you to print from your phone. If you have an HP all-in-one, there is another app that allows you to scan directly into your phone. I believe the other manufacturers have similar apps if you have a web enabled printer.
    If you sign your printer up for Google Cloud Print, there is a Cloud Print app.
    There are some limitations as to the type of files you can print from these apps, but both will handle most file types you have on your phone. I find that the Cloud Print app will handle more file types, but some times it takes a while for the Google Server to send the information to the printer. I believe the Cloud Print app also has the capability to save the printout as a PDF.
    I've tried all of those and I can't print a S Note. I can print most stuff with those apps. I want to print the actual note itself
    Sent from my SCH-I605 using Tapatalk 2
  6. #6
    DroidXcon's Avatar
    Posts
    Global Posts
    11,775 Global Posts
    ROM
    Stock for now
    Quote Originally Posted by husa3695 View Post
    Don't know how. You could screen shot the note then print the screen shot
  7. #7
    Open the S Note. Press settings, but then select Share rather than Print (print gives you the samsung printer only option). Share asks if you want text, jpg or pdf, then offers all of your apps, including cloud print and Drive.
    Thanked by 2:
  8. #8
    I also use print share with the s note. I am using a Canon printer but with printshare I don't think it matters. The app is in the playstrore and cost is $15.00 i think. But it works.
  9. #9
    There isn't a good way to print PERIOD. I have had this same frustration. Why can't we print DIRECTLY from the note itself!? I use the HP ePrint app because I have an HP wireless printer. Here are the steps I take: 1) Save note 2) Export note as pdf 3) Open HP ePrint and scroll down through ALL of the notes I have done this with previously and find the one I just exported.4) Open the pdf version and hit print. Pointlessly tedious.
    Thanked by:
  10. #10
    I have a Canon printer that is wifi and have Printshare installed, but it cost $15.00 for Printshare but as much as i use it its worth it for me. I save the s note and hit the drop down menue and hit print. The printshare app shows up and its done.
    Attached Thumbnails Attached Thumbnails How do I print a S Note? I don't have a Samsung printer.-uploadfromtaptalk1371137103508.jpg   How do I print a S Note? I don't have a Samsung printer.-uploadfromtaptalk1371137117360.jpg
    Thanked by:
  11. #11
    Google just put Cloud Print in the Play store. There were other apps to do this before, but this one is free and properly google-integrated. It only takes a minute to set up Google Cloud Print via your Chrome browser.
  12. Thread Author  Thread Author    #12
    Quote Originally Posted by srayjacobs View Post
    Thanks that worked. I tried to print from my phone and that didn't work now I tried on my tablet and it worked. I got Printshare for free from Amazon App store a couple of years ago. My Note 2 is from Verizon so that could be the problem too. Thanks again.
  13. #13
    Use Print Bot Pro, it's in the play store. well worth the paid version.
  14. #14
    "Let's Print Droid" on google play store do the same as "PrintShare" for free. Not affiliate, just a happy user
    Thanked by:
  15. #15
    I think the OP means that even though S Note has a "print" option in its menus, when you try to print a note it tells you that "S Note only prints to Samsung printers. No printer detected. " (?!?) There is no option to select cloud print or other printer from within S note on the Note 8. I ran into this sillyness too.
    WTH Samsung? That's a Sony or Apple proprietary-hardware-esque move. I don't even think I could even find a Samsung printer in the markets here if I wanted to. Drastically limits the functionality of S Note & the Note family for productivity / business / office use. Am I missing a setting somewhere?
    Thanked by:
  16. #16
    I'm not sure about the Note 8, but when using Google Cloud Print on an S3, you use "share" rather than "print", then choose the cloud print app. Assuming you have set up Cloud Print via the Chrome browser, it works fine.
  17. #17
    wow..been having mine this long and didnt know that..lol...Im on hyperdrive wonder if it still would work
  1. How do you protect your precious Note II?
    By Persill in forum Samsung Galaxy Note 2
    Last Post: 07-27-2013, 10:53 PM
  2. How do I print pictures in emails
    By Newtoandroid99 in forum HTC One X
    Last Post: 05-21-2012, 09:27 PM
  3. how do i print from my gnex over wifi or do i need a app?
    By bobgilbert11 in forum Verizon Galaxy Nexus
    Last Post: 01-13-2012, 05:16 PM
  4. How do I print from my Skyrocket?
    By poconojoe57 in forum Samsung Galaxy S II Skyrocket
    Last Post: 01-10-2012, 10:39 PM
  5. [?] How do you use Voice Memo / Note to self
    By jefboyardee in forum LG Optimus S
    Last Post: 01-22-2011, 10:51 AM
