1. ababili's Avatar
    Hello everybody,
    I'm using Galaxy Note 10.1 for about a year now and I found handwriting in Gmail, Firefox etc very-very useful.
    Yesterday, the firmware of the device was automatically updated, and since then I can use handwriting only in S-Note and no other app.
    Any idea how I can get handwriting back in all the apps?
    Thanks a lot!
    07-03-2013 01:20 AM
  2. Mom2Ninjas's Avatar
    What firmware did you get updated to? On your keyboard do you a microphone symbol? When you press and hold that you should get more options. The T with the pen is for handwriting.
    07-03-2013 11:09 AM
  3. ababili's Avatar
    Hello, Mom2Ninjas, and thanks for trying to help.
    Unfortunately, it was exactly this symbol -the pen- that was missing (I only had the microphone and the Settings symbol).
    I even called Samsung's customer support, talked with them for over half an hour and they had nothing else to suggest than "restore to factory settings" and that's what I did
    Now everything seems to work fine.
    07-03-2013 12:59 PM
  4. Mom2Ninjas's Avatar
    That is so weird. Did you maybe have a new keyboard?
    Are you rooted?
    What firmware are you on?
    07-03-2013 01:08 PM
  5. Terran White's Avatar
    That's so unfortunate. I believe turing off the device a few times would have helped. With new updates in either firmware or software, the device needs time and rest in order to work properly. Next time this happens, restart at least 3 to 5 times.
    07-04-2013 12:33 PM
  6. cordoni's Avatar
    For the penvto work, you have to use the stock keyboard. It will not activaye otherwise.
    07-05-2013 10:16 AM
  7. munkyphunk's Avatar
    I had this problem too. After reading this thread and playing around I discovered you need to hold down the "cog" settings button and select the "T" from the pop-up menu. thanks for pointing me in the right direction folks!
    07-13-2013 04:46 AM
  1. HELP! I can't root my samsung galaxy s3
    By jclopez24 in forum Samsung Galaxy 3
    Last Post: 12-04-2014, 08:06 PM
  2. Replies: 2
    Last Post: 07-14-2013, 10:05 PM
  3. LGOG have known issues with SD card?
    By RenoD2010 in forum LG Optimus G
    Last Post: 07-03-2013, 12:13 PM
  4. Anyone using tablet encryption on the N10?
    By James Temple1 in forum Google Nexus 10 Tablet
    Last Post: 07-03-2013, 12:27 AM
  5. Replies: 0
    Last Post: 07-02-2013, 11:11 PM
