I have had my Note 10.1 for about 9 months. Until recently the only complaint I have is how it works with a Bluetooth Keyboard.
Here is my situation ... and is it a Problem or Coincidence? ... I purchased a new case with bluetooth keyboard. I purchased the Aluratek Slim Color Folio Case with Bluetooth Keyboard for Galaxy Tab2 / Note 10.1. At the same time I purchased the case I received an update which I installed. I noticed almost immediately three things.
1. It seemed to take longer then normal to charge.
2. One spot on the Note was always warm (even when idle). Sometimes it would get very warm. Before I had only noticed it getting warm when charging toward the right side.
3. The battery would run down in 7 to 8 hours.
This went on for three days. After checking all settings to make sure all "sync" settings were at manual (where possible), and after uninstalling a sync hog like weather bug, it seemed to not make a difference. I then decided to back up and do a complete reset. Following the reset I received another update. I re installed the apps, actually leaving several off just in case it was one of them causing the issue. Still the same result. Long charge and about 7 hours until it needed another charge.
I bring the case into the picture because it contains a flap/stand that is a magnet. I wondered if that could be a problem. This is where the coincidence comes in. I would think not but since I started using it at the same time as the first update came in .... I wondered.
Last night I had a new twist in all of this. I fully charged my tablet before retiring for the evening. I always read prior to lights out. When I idled my Note and put it on the bedside stand I though everything was OK. It showed a full charge. This morning when I woke up it was completely discharged. Now this took place between 9:30 last night and 5:15 this morning. I also noticed something else. A crack in the upper right of the screen (see picture). I also noticed that the Note was very warm .... even though it was fully discharged.
I wonder what everyone's thoughts might be. Coincidence or do I have a problem? Could the magnet in the case have anything to do with it? Could my battery be going bad and causing excessive heat? Could the updates have screwed things up? A lot of questions. I don't want to purchase and install a new glass only to find out I have other problems.
Please ... what are your thoughts??
