Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Ember61
    Default Battery takes forever to charge
    My tablet can charge for 8 hours and only gain 10% want should I do? I am using the original charge cable and plug please help
  2. #2
    Default Re: Battery takes forever to charge
    It definitely shouldn't take that long. Have you tried another charger?
  3. #3
    PRess the power button and the volume down button at the same time and hold until the unit restarts... it resets the charging cycle and the note will charge reasonably quick from then on... I do this on occasion when my battery seems to charge slow.
    Sent from my GT-N8013 using AC Forums mobile app
    JM Colorado likes this.
    I tried restarting it but that didn't work....and no I haven't tried a new charger but the one I'm using now is the original and is in perfect condition..
  5. #5
    Try another charger. This is a common problem. Mine was faulty replaced it with a belkin charger.
  6. #6
    Default
    Quote Originally Posted by prestonmiller91 View Post
    Take a close look at the tablet's and the cable's port for lint or down bent pins.
  7. #7
    If you buy a replacement make sure the output says something like 2 A or 2.1 A.. There are a lot of chargers for phones that are only 1 amp and you'll get the dreaded red x over the battery icon if the output is too low. Also, I know it's a fluke, but try a different outlet. I've noticed mine charges slower if I use the extension cord in one room.
  8. #8
    I have the same problem. It did not exist before I updated to lollipop ota. It is not the cable/charging system.
    Could someone clarify the reset process?
    Thanks
  9. #9
    Default Re why Battery takes forever to charge 4.4 tablet.
    take so long to charge on 4.4 tablet
  10. #10
    Had the same problem with a brand new Tab 10.5 S . Took forever to charge. Finally noticed a red 'X' over the battery icon. Changed the USB cable that came with the unit. Works like a charm now.
  11. #11
    Question Re: Battery takes forever to charge
    So dumb question..... but will it restart the tablet completely, all on it's own? I tried this but idk if I'm doing it right lol!
  12. #12
    Kimmyone's Avatar
    Posts
    Global Posts
    3 Global Posts
    Default Re: Re why Battery takes forever to charge 4.4 tablet.
    Quote Originally Posted by Ronald Godsalve View Post
    I have same one as you only had it a year and I barely use it, for same reason , because I charge all day get 26% and when I use it after 10 minutes battery's drained to 15% and then it goes off again . I'm basically paying for something I can't use
  13. #13
    I've had this problem a couple of times and on both occasions it was the cable. It seems to be particularly fragile as it enters the plug at the device end. They are expensive to replace at €25 ($26 or £21) but at least my second cable was less than 1 year old so still under guarantee.
  1. Battery Drain While Phone is Off
    By rlakritz in forum Samsung Galaxy S4
    Last Post: 11-23-2013, 07:43 AM
  2. I don't know what to do.....
    By redimpala01 in forum Samsung Galaxy Note 3
    Last Post: 11-16-2013, 06:32 PM
  3. Moving apps from home screen to app pages
    By crystalespers in forum Samsung Galaxy S3
    Last Post: 11-15-2013, 06:00 PM
  4. how to find software version on a dead phone?
    By Ciorstan MacGregor in forum Samsung Galaxy Ace
    Last Post: 11-14-2013, 12:14 PM
  5. Battery apps don't work on Kit Kat, N5
    By justlaxin13 in forum Google Nexus 5
    Last Post: 11-14-2013, 10:18 AM
