Results 1 to 6 of 6
    BgDM's Avatar
    Posts
    Global Posts
    44 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Note 10.1: Not Charging
    Looks like my unit is no longer charging. When I plug in the 30 pin I get a pop-up stating "Battery Critically Low - Disable all apps to conserve battery." I get the "Lightning Bolt" icon over the battery icong stating that it is charging, or powered, but it will not charge the battery.
    My 30 pin cable is a bit worn at the connection. Maybe this is the issue? But it does stay powered when plugged in. Not sure if it is a battery, or just the cable.
    Any suggestions?
  2. #2
    camo15's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Not Charging
    Its the same with mine can't seem to find a solution.
    BgDM's Avatar
    Posts
    Global Posts
    44 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I found a thread here that said to hold both the POWER & LEFT VOLUME buttons at the same time. I did that and it seemed to reset. Seems to be fine now. Very odd.
    BgDM's Avatar
    Posts
    Global Posts
    44 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    OK, so I seem to be able to charge now, but it will only charge to about 35-40% and that is as far as it gets. Anyone have any suggestions?
  5. #5
    mrsmumbles's Avatar
    Posts
    Global Posts
    4,272 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Note 10.1: Not Charging
    Are you using the OEM charger and cable?
    Sent from my Nexus 5 using Tapatalk 2
    BgDM's Avatar
    Posts
    Global Posts
    44 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes. Might need to order a new one.
  1. Bluetooth disconnecting if not paired
    By asteriks in forum Samsung Galaxy Note 3
    Last Post: 01-13-2014, 10:29 PM
  2. My tablet has suddenly stopped charging and responding
    By Tezza20 in forum ASUS Transformer Pad TF701
    Last Post: 01-13-2014, 10:54 AM
  3. ROGERS-4.3 downloaded but not installed
    By bobcagin in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 01-13-2014, 06:15 AM
