Results 1 to 4 of 4
    JD2
    JD2 is offline
    JD2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Note going nuts
    Got the 10.1 for Xmas and it's been ok until yesterday. When I touch the home button it has a circle that says 'google' at the top and a fingerprint emblem shows as I touch it. It's also been acting like someone else has remote control of it, like it has a virus or malware. For instance, I'll go to settings and the wifi stuff is on the screen and it puts each one I have showing in the field and I have to cancel out of each, very frustrating. Also does that with other apps and settings. I have AVG antivirus app but it will not run. Any suggestions? I have no confidential info on it, and will probably keep it that way if it has vulnerabilities.
  2. #2
    Gekko's Avatar
    Banned
    Posts
    Global Posts
    8,236 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Note going nuts
    1. issue #1 sounds like you are simply swiping up and activating "Google Now".
    2. issue #2 needs to be clarified by you.
    JD2
    JD2 is offline
    JD2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks Gekko. How do I de-activate google now?
    Not sure what you mean by issue#2, but the unit acts like someone else has control of it. Does this thing use the smart stay feature to open apps you're looking at. It almost seems that's what it does...very weird.
  4. #4
    enigmax's Avatar
    Posts
    Global Posts
    235 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You may want to try this one:
    https://play.google.com/store/apps/d...wswipedisabler
    Sent from my GT-N8000 using Tapatalk 4
  1. Unable to delete the folder created on app page in my Samsung Note 3
    By Krishna Naik in forum Samsung Galaxy Note 3
    Last Post: 06-07-2015, 11:44 PM
  2. note 3 bluetooth problem
    By subzero1993 in forum Samsung Galaxy Note 3
    Last Post: 02-13-2014, 03:57 PM
  3. Note 3 Maps & MMS
    By ksaxi in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 02-07-2014, 09:24 AM
  4. The Ultimate Galaxy Note 3
    By Anon8154066 in forum Samsung Galaxy Note 3
    Last Post: 02-04-2014, 02:30 PM
  5. Sync S Note to PC with texts (Evernote turns text into jpeg)?
    By anandroiddummy in forum Samsung Galaxy Note 3
    Last Post: 02-02-2014, 08:38 PM
