1. visch1's Avatar
    Apparently I overdosed on American Stupid pills when I purchased my new out of the box 2 days ago Note 10.1 2114 with Version 4.4.2. My primary use for it is listen to MP3s and watch movies installed on the cards. After formatting the first card in the unit I used a card reader and put into it a couple MPs . That seemed fine so I TRIED TO delete the MPs still connected to the computer and I cannot get rid of them nor is it able to be formatted by the Note 10.1.
    I tried formatting also using Windows and Disk Director 11. Nothing works as far as formatting goes all I get back are unable to proceed or unable to locate card. So being stupid I tried the second NEW card figuring the first is bad. Same thing so now I have 2 unusable cards.
    So what stupid thing should I do now? Run over it with my truck or #7 in my shotgun? Kindly explain in terms your grandparents would understand, Im that old. BE WELL AND TYIA
    05-17-2014 07:44 AM
  2. Golfdriver97's Avatar
    Perhaps a restart of the PC?
    05-17-2014 08:23 AM
  3. visch1's Avatar
    thanks for the comeback. I've restarted both the PC and Note a # of times. I find it odd that trying to format so many times and ways I can play the MPs I tried do delete many times. I wonder if the Sandisk Micros are both defective? Just thinking.
    05-17-2014 09:00 AM
  4. Golfdriver97's Avatar
    Possible. I haven't used SD cards in quite some time.
    From an SOKP Nexus 5
    05-17-2014 09:29 AM
  5. visch1's Avatar
    I tried a second card reader with no success. In thinking back both cards had a read error trying to import the MP folders. I don't want to sacrifice another one to test any ideas I have so am going around in circles. So far I've tried 4 different apps to format the cards and none of them work as far as removing anything on them. I need HELP OR IDEAS!
    05-18-2014 07:01 AM
  6. Golfdriver97's Avatar
    Have you had a PC check them for errors? Place the card in the PC and right click, then click Properties. Then under tools should be an option to check for errors.
    05-18-2014 07:59 AM
  7. visch1's Avatar
    Yes I tried several different checks and all reported back "healthy". Maybe healthy but still wont work.
    Came across the following and this type of situation is not new. Perhaps there will be an outcry when more discover things seem fried.
    cannot format micro sd, believe me, i tried everyt... - Page 3 - SanDisk Forums
    05-18-2014 10:11 AM
  8. Golfdriver97's Avatar
    I am not sure what else to suggest. Sorry.
    visch1 likes this.
    05-18-2014 10:25 AM
  9. visch1's Avatar
    Well I think the best I can do now is return them and order a couple Samsung cards. This may be a brand specific problem.
    Thanks for your input. BE WELL
    05-19-2014 07:18 AM
  10. Golfdriver97's Avatar
    I hope it works out. Good luck.
    05-19-2014 07:58 AM
  11. visch1's Avatar
    An update. Both Sandisk Micros were returned and replaced by 2 Samsung 32Gb microSDHC cards. The first one works fine so far. BE WELL
    05-23-2014 06:55 AM
  1. Is green tint still a problem?
    By Mooncatt in forum Verizon
    Last Post: 05-19-2014, 03:30 PM
  2. update problems
    By grn4frk in forum Motorola Droid MAXX
    Last Post: 05-19-2014, 12:50 PM
  3. videos pictures sd card help
    By Bob Walker1 in forum LG Optimus Series
    Last Post: 05-19-2014, 12:08 AM
  4. Replies: 13
    Last Post: 05-18-2014, 02:48 PM
  5. Micro SD Card Not Working into Other Devices
    By bijutoha in forum AT&T Galaxy Note 2
    Last Post: 05-17-2014, 07:45 PM
