[AT&T][GALAXY NOTE 2] ***How To Root***
Ok my ATT GN2 friends is it time to root?
The answer is yes if you want the latest & greatest android user experience because ATT etc carriers sure is heck aren't going to make it happen anytime soon.
Is rooting hard to do?
No its very easy.
What does rooting do for me?
It allows you to install custom roms with the most up to date base , No bloatware that slows OS function , customization , Themes , tweaks etc on your device.
So basically make device you spent lots of money on truly yours.
Whats the danger of rooting....will it void my warranty?
There is No danger in rooting because restore tar is available that holds factory out of the box OS so If you need to take device in for service simply Odin stock tar warranty isn't void.
Now lets get down to business :)
(ROOT FOR WINDOW USERS)
Follow steps below in order , If you have any questions....get lost or confused feel free to ask for help.
After 2 steps below are complete you are truly free to enjoy what your device has to offer.
Step #1 - Rooting:
Direction & files needed to root device - [Only registered and activated users can see links. Click Here To Register...]
Step #2 - Recovery:
You have two recovery choices
TWRP & CWM method. I highly recommended TWRP method because of its ease of use.
1st choice TWRP Method:
Install TWRP recovery using goomanager watch how to video- [Only registered and activated users can see links. Click Here To Register...]
2nd choice CWM Method:
Follow direction in link - [Only registered and activated users can see links. Click Here To Register...]
(ROOT FOR MAC USERS)
This method uses CWM as recovery.
Rooting - [Only registered and activated users can see links. Click Here To Register...]
After complete you can install TWRP over top , It can be done using goomanager Watch video how to [Only registered and activated users can see links. Click Here To Register...]
After complete you are now ready for flashing action!
Some Safety rules:
1)ALWAYS MAKE RECOVERY BACKUP BEFORE FLASHING ANYTHING.
2)Only flash roms & tweaks that are modified for are version of device. Many of those can be found at XDA ATT GN2 forums
Enjoy & dont flash drunk :confused:
Phil-
