JayRatliff
Re: Best Custom ROM
You are welcome, just flash the dang thing, it takes about 3-4 minutes to wipe and flash. Then it will take a few minutes for the phone to come up the first time you boot it after you flash it, don't freak out, it is writing all temp files and setting everything up prior to loading the launcher.
****A few words of wisdom from Scott:****
Do NOT flash Mods or Themes unless they say CleanROM ACE 4.0 compatible!!!!
Clean flashing is the only recommended flashing method! Anything else WILL lead to problems! Trust me!
If you have problems go back and wipe data and re-flash. Do not report in the forum until you do so!
If you fail to wipe Clean or you choose to restore data / apps or anything else from back up apps like Ti Back up you will suffer from a seriously degraded experience!
If you flashed a Mod / Theme or Kernel do NOT report any bugs until you wipe Clean and re-flash with only options included in the ROM!
Do it by hand or dont do it at all!
1. Done
2. Done
3. Will do
4. Will do.
5. Will do.
6. Will do.
7. Will do.
8. Thank You.
