1. jluna1's Avatar
    I was wondering if anyone can help me out with the boot loop my Note II is stuck on. I was running My Rom and decided to download and try MY UI rom. I downloaded the rom and using Rom Manager I had the phone boot into recovery wipe and install. The phone booted into recovery and and started to wipe like it normally does. It gets as far as Formatting /data but then reboots. It goes back into recovery and does the Formatting /data and reboots again. I tried taking the battery out waiting a little bit and put it into download mode so I can flash with odin but it just boots into recovery and starts to wipe and reboots. Any ideas on how to fix this?
    01-07-2013 07:36 AM
  2. DroidXcon's Avatar
    From now on dont use Rom manager. So when you press volume down/home key/ then press and hold power it goes to recovery?
    From my Galaxy Note 2 via Tapatalk
    01-07-2013 08:29 AM
  3. jluna1's Avatar
    I agree, don't want to risk this happening to my S3 as well. Yes that is correct. Even if I pull the battery put it back in and just press the power button it boots into recovery and starts to wipe and reboots.
    01-07-2013 03:00 PM
  4. DroidXcon's Avatar
    Sounds like you flashed something for a different phone. Did you download the rom from rom manager aswell?. Try pulling out the battery. Connecting to the computer. With the battery still out try getting into download mode
    01-07-2013 03:04 PM
  5. jluna1's Avatar
    No I just used it to back up and flash. I downloaded the Roms from the Xda Forum. Thank you I will try that, hopefully it works.
    01-07-2013 04:12 PM
  6. DroidXcon's Avatar
    Can you link me to n the rom you b were trying to use
    01-07-2013 04:25 PM
  7. jluna1's Avatar
    {ROM}{-MyRom V3-}{-T-MOB 4.1.1-}{-UVALK8-}{-AROMA-}{1-4-13-} - xda-developers
    Downloading original T-Mobile frimware now. Hopefully it works.
    01-07-2013 07:01 PM
  8. DroidXcon's Avatar
    How is it you boot into download mode without the battery? Do I hold down power and volume buttons while plugging in the USB?
    No . Plug in first. Hold down volume down+home button. Continue to hold them and press power. Keep holding all three til it brings you to the accept or cancel screen. Then you can pop the battery back in
    01-07-2013 07:10 PM
  9. prepaidguy9081's Avatar
    Rom manager = brick
    I trust it on no device.
    If you want somthing done right do it yourself the long way lol
    Sent from my SGH-T889
    01-15-2013 11:54 PM
  1. How do I get past the activation screen?
    By jakeroberts42 in forum Verizon Droid Incredible
    Last Post: 03-16-2013, 11:04 AM
  2. Mobile APN disabled cant get MMS
    By digink#AC in forum HTC EVO 4G
    Last Post: 09-14-2010, 01:27 PM
  3. Can't Get Past The First Step
    By Falconfree in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 08-18-2010, 06:51 PM
  4. Can't get past the Google Login screen! (No data plan)
    By i6mpower in forum General Help and How To
    Last Post: 08-09-2010, 10:55 PM
  5. Can't get past the warning triangle
    By bdotto14 in forum Google / HTC Nexus One
    Last Post: 06-18-2010, 01:40 PM
