I have many radios available, I tried flashing stock radio from rogers my service provider. When I flash using recovery mode it completes the process but still after the boot my service is not back and in settings menu baseband version is unknown.
Why are you flashing everything with odin. Odin flashes the root file only. Everything else flashes with TWRP or CWM. I recommend TWRP.
Also it kinda sounds to me like you flashed an att mod or rom to a rogers device.
Sent via Tapatalk
No. He says rogers is his provider. They have a different model number than att. The roms and mods are not hackwards combatible afaik. His problems most likely stem from flashing a mod not meant for his carrier.
Sent via Tapatalk
hi can i get different link this one is not working
Did you ever get this fixed for this person? I have the same exact issue. Any help would be appreciated.
