1. crasherkid's Avatar
    hey guys im in a bit of an akward situation... ok the problem is ive played around with different kernels and some different roms but now the bluetooth wont turn on and more importantly USB doesnt work, usb will charge the phone but it will not connect to pc.. any pc.. it just charges,ive tried restoring back to previous saves ect and installing kies removing drivers ect ect just about everything forums throw at me. The main issue i have is if i want to return back to the provider for a repair/exchange i cant get the original kernal and rom and i cant flash it because usb doesnt work i have installed cwm mobile so maybe can do it that way ? also using triangle away hasnt changed settings>about device>status>device status=modified
    So if anyone has any ideas where to go from here id be very much gratefull soooo frustrated
    oops sorry if this is in the wrong section.
    02-04-2013 06:07 AM
  2. MHH779's Avatar
    Have you done a system reset in your recovery?
    I have TWRP recovery and it has that option which resets your system..
    If there is really nothing important in your phone or you have SD card, move everything you need to it than go to recovery and reset everything says reset.. Your system, internal storage, caches, format the phone.. than put a ROM in your SD and flash it..
    (I did that on my note 2 on TWRP recovery, Do it at you own risk)
    I think you can unroot your phone with an option in SuperSU
    02-06-2013 07:36 AM
  1. UnRooted EVO 4G! Please help!!!
    By PointDexter85 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 02-25-2012, 08:12 AM
  2. Having a tough time unrooting unrevoked 3. Please help.
    By awhitt10 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 02-18-2011, 09:09 PM
  3. Please help! Problem with unrooting Moto Droid!
    By LakersGuy89 in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 09-17-2010, 07:01 PM
  4. USB Problems, PLEASE HELP!!!
    By rob989_69 in forum AT&T Captivate
    Last Post: 07-25-2010, 08:53 PM
  5. Please help unrooting
    By xxdrizkidxx in forum HTC EVO 4G
    Last Post: 06-20-2010, 05:11 AM
