Sound Search and Battery life
destefmx6
126
Sound Search for Google Play is killing my battery.... 50% of the use.
It killed the battery in 9 hours?
Can I uninstall it without any problems to other apps?
I dont have that on my phone afaik. I would kill the process and see if it changes anything. If after a day or 2 and you notice no issues with the killed process it MIGHT be ok to uninstall it. Is that part of a rom you installed or is it part of an app.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
I don't think I even use the process........but, I will kill it, clear it, and see what happens. To be honest after the scare I had when it was stuck in the Loop, this is minor.....
slackingfred
