1. sithjedi333's Avatar
    Sorry for such a basic question. I'm thinking of moving from the 64GB iPhone 5 to the Note 2 on Verizon. However I'm concerned about the lack of memory, since I use Spotify and games.
    If I root the phone, can I transfer applications to the SD card? I did a search and it sounds like after rooting, the apps to accomplish this no longer work well. Also I would like to retain Samsung functions like multiwindow.
    Is this possible? Any pointers on which ROMs/apps to load would be greatly appreciated.
    Thanks!
    04-21-2013 08:58 AM
  2. sithjedi333's Avatar
    Please delete, wrong forum, thanks.
    04-21-2013 10:58 AM
  3. jdub1981's Avatar
    Thanks!
    You are in the correct forum, the mods may have moved your post. Rooting by itself will not give you this ability to moves apps to sd. But there is a mod that will allow you to swap internal for external memory. I have not done it but I have read that it does infact work. It also recommended that you use the fastest memory available which at this time is going to be a sandisk 64gb class 10 uhs-1 micro sd card, or equivalent. They are appr. $49 on amazon or $99@ BB.
    Sent from my Galaxy Note 8.0 using Tapatalk
    sithjedi333 likes this.
    04-21-2013 01:54 PM
  1. A couple questions about rooting. Is it always fixable, best way on a mac, and such.
    By Skyshayde in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 12-30-2012, 02:19 PM
  2. Question about rooting/installing roms on an unactivated phone.
    By goisasrt in forum HTC V 4G Rooting, Rom's, and Hacks
    Last Post: 08-28-2012, 11:24 AM
  3. Question about Rooting my Note
    By enduser2941 in forum Samsung Galaxy Note
    Last Post: 08-18-2012, 10:24 PM
  4. Questions about upgrading on Verizon family plan
    By Carbon Stig in forum Verizon HTC Thunderbolt
    Last Post: 03-15-2011, 11:10 PM
  5. Question about Droid on Wirefly.com
    By Mysteria in forum Motorola Droid
    Last Post: 12-05-2009, 10:54 AM
