Results 1 to 8 of 8
    Default Tethering not working !!Unlocked At&t phone but using it w/ T-Mobile
    I have an unlocked At&t Note 2 but I am currently using it with T-mobile, when I try to turn on the mobile hotspot it immediately turns off and tells me "Mobile Data is not available or Invalid SIM". My phone is currently running 4.3 Jelly Bean and I do not want to root it.
  2. #2
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    Default Re: Tethering not working !!Unlocked At&t phone but using it w/ T-Mobile
    Quote Originally Posted by Hugolara10 View Post
    Do you have tethering/hotspot enabled on your plan? If not, maybe try something like Foxfi.
    https://play.google.com/store/apps/details?id=com.foxfi
    Yes I have tethering/hotspot in my plan... when i had my phone running 4.1.2 i had the same message but FoxFi fixed the problem, but since i updated to 4.3 not even FoxFi has worked.
  4. #4
    I may be wrong but didn't 4.3 break that ability ? Idk if there is a workaround. You can check on xda.
    Sent from my iPhone using Tapatalk
  5. #5
    Been hunting for an answer too. No luck anywhere on the net.
  6. #6
    Hey fellas. New to the site but my problem brought me here. I have a similar problem to this. I'm actually looking into updating to 4.3. Currently have a at&t note 2 but its unlock cause I'm running t mobile sim card. How do I update!? Any help would be appreciated. Thanks in advance
  7. #7
    I'm in kinda the same situation....have an AT&T Galaxy S5 running on a T-Mobile sim. While I do have tethering allowed by TMo can't get it to work on Kit Kat......anyone have any suggestions?
  8. #8
    Same problem here with rooted AT&T Note 3 4.4.2 on T-Mobile.
  1. Tethering not working !! At&t phone but using it w/ T-Mobile
    By Hugolara10 in forum T-Mobile Galaxy Note 2
    Last Post: 09-29-2014, 10:08 PM
  2. Phone - Malicious hacking
    By rap1 in forum General News & Discussion
    Last Post: 02-08-2014, 08:30 PM
  3. I need help choosing a device for work
    By yunvi in forum General News & Discussion
    Last Post: 02-07-2014, 09:36 AM
  4. Phone calls break Bluetooth connection
    By livewiremaxx in forum Verizon Galaxy S3
    Last Post: 02-05-2014, 02:43 PM
  5. Replies: 4
    Last Post: 02-05-2014, 08:48 AM
